must be removed
that's not good :/ Here I can see removed also all top of the manifold. I'll have to change all cooling pipes, pressure, and relocate throttle body. It is a lot of changes. If I just disconnect pressure pipes which are controlling DISA (like HaNasich said), does it work then? Manually removeing will be the best solution. I know that now, but I need easier way.
in metalic disa open the side cover remove the buterfly leave tha axle and you are ready (or leave it like that)in plastic one brake the plastic butterfly and cut the axle that moves the butterfly a lot of people do that here in greece dont desconnect it otherwise you gone run in save mode map sorry for my english...
