Author Topic: light weight flywheel  (Read 6292 times)
Hodge
« Reply #15 on: August 05, 2009, 08:25:09 AM »
It doesn't, because it is a dual mass...There isn't really much of anything to take off. IIRC only single mass flywheels can be shaved down.
Speaking of which, I think you can use the M40 single mass stuff for an easy swap too.
1995 E36 318isc
max123
« Reply #16 on: August 05, 2009, 03:57:52 PM »
But all non-AC cars have single mass flywheels, right?  If that's the case, then I would opt for the machine shop.  Alternatively, the Metric Mechanics Single Mass Flywheel is only $350 +core.  Which isn't half bad.
Hodge
« Reply #17 on: August 05, 2009, 09:01:27 PM »
Most probably d, for good reason.
Dual mass flywheels suck up TONS of vibration and noise...move to a single mass and you get alot more noise. Especially if the A/C is on.
1995 E36 318isc
Janne
« Reply #18 on: August 16, 2009, 06:14:31 AM »
Quote from: Hodge;75898
I have the UUC 11.5# flywheel and love it. It chatters alot when the A/C is on and a tiny bit when it is off, but I don't care. Engine revs so smooth.
Do this UUC 11.5 flywheel have the TDC-hole?
Have you take 0-100kmh time with your lightweight flywheel?
Im thinking to buy that flywheel-clutch combo on understeer.com but they dont answer to my email:(
Where the company are located? Usa?
318lotis
« Reply #19 on: August 17, 2009, 04:09:13 PM »
pelican has a single mass flywheel for our car, for without ac,the European version they have this in stock.
robweenerpi
« Reply #20 on: August 18, 2009, 12:03:40 AM »
Quote
Quote
Same thing, but I have this setup and it's nice.  Clutchmasters rebuilt the stock kit for me and beefed it up.  A machine shop can cut a bunch of weight off there too.  Stock for stock the M40 setup is only like 5 pounds lighter.  Mine is now 26 pounds with the clutch and flywheel together.
