DISCUSSION
Engine + Driveline
Potential oil leak sources?
Topic: Potential oil leak sources? (Read 2116 times)
KenC
Sr. Member
November 28, 2008, 05:07:55 PM »
I have an oil leak coming from the driver's side of the engine. I replace the upper pan gasket last night and it still persists. It looks like it's coming from somewhere around the oil filter housing, but I don't think it's leaking from it. Are there any other potential sites of leakage on the driver's side of the block?
Thanks,
Ken
strad
November 28, 2008, 07:30:43 PM »
I've had all that stuff off that side of the motor, and I'm not aware of anything other than the oil filter housing gaskets and o-rings, the valve cover gasket, the chain case gaskets and the upper pan gasket that are anywhere near there.
bearsbmw
Sr. Member
November 28, 2008, 08:38:43 PM »
what about oil dip stick housing?
KenC
Sr. Member
November 30, 2008, 10:10:27 PM »
Quote from: bearsbmw;61890
Higher than that. I'm going to take the oil filter housing off and take a look.
DISCUSSION
Engine + Driveline
