Author Topic: cyl comp #'s  (Read 2176 times)
PaulC
cyl comp #'s
« on: August 14, 2008, 02:58:38 AM »
Tried the search. I'm wondering about some of the numbers on M42's running around. Mine are 247, 243, 250, 249. Looks like the head was cut.
Jimmy Lewis
cyl comp #'s
« Reply #1 on: August 14, 2008, 09:06:47 AM »
That sounds right for a test with 10 turns of the starter, the numbers are high and very close. You seem to have a very healthy engine with close to no blow-by. I don't think compression ratio effects the outcome of a compression test, it measures how tight the tolerances are between the rings and cylinder walls rather than the ratio. Though, with numbers that good on such an old motor it is possible it has seen a rebuild.
« Last Edit: August 14, 2008, 09:09:38 AM by Jimmy Lewis »
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
KenC
cyl comp #'s
« Reply #2 on: August 14, 2008, 09:14:09 AM »
How many turns of the starter are you doing?  That's really high for even a healthy stock engine.
PaulC
cyl comp #'s
« Reply #3 on: August 14, 2008, 11:42:41 AM »
The car has 92K and I don't know the history other than that. Did the test with around 10 turns. The head looks like it has been off before and probably cut, the upper tc cover doesn't line up. And thanks, it feels really healthy.
PaulC
cyl comp #'s
« Reply #4 on: August 15, 2008, 03:31:38 PM »
Is there a thread I missed where people posted their #'s?
