Author Topic: How to remove intake manifold completely?  (Read 2549 times)
Frankie
« on: March 09, 2008, 07:06:41 AM »
I have removed the upper part of the intake manifold and throttle body. I want to remove also the lower part in order to change the gasket.
Does anyone have any good instructons for removing the lower part?
It seems that I have to remove injectors and take the clutch cylinder hose out of the manifold?
What else should be take into account before proceeding?
RED IS 91
« Reply #1 on: March 09, 2008, 07:50:15 AM »
Have you searched the online manual ?
http://www.m42club.com/forums/showthread.php?t=964
Frankie
« Reply #2 on: March 09, 2008, 08:15:54 AM »
Yes, I have. But the manual seems to skip few things, like that hose coming from brake sylinder??
Do I have to remove injectors for removing the lower part of the manifold?
« Last Edit: March 09, 2008, 11:31:59 AM by Frankie »
« Reply #3 on: March 09, 2008, 09:37:30 AM »
to remove the lower part of the intake... there are 5 or so bolts...!!thats all.. no lines to remove.. no injectors to remove.. you have to look at it, its built very simple..
