Author Topic: 91 318is engine problem  (Read 3000 times)
logger
« on: March 12, 2007, 09:22:34 PM »
I have a 91 318is when I get to about 4000-4500 rpm when it should be starting to excellerate faster I get a lag in power , continues to reach 7000 rpm but not as fast . Currently also have engine code 1222 . mods are dinan chip exaust and intake . Any info would be nice .
Loghan
individualist
« Reply #1 on: March 13, 2007, 03:53:09 AM »
Code is Lambda Control 1, I had that one the other day. It was a vacuum line that had come off the fuel pressure regulator. Start checking for vacuum leaks under and around the intake.
Alpine003
« Reply #2 on: March 13, 2007, 07:44:09 AM »
Quote from: individualist;21182
The vacuum line to the fuel regulator has a tight kink to it and can often crack without it being noticable. Take off your fuel pressure regulator vacuum line and carefully check it for cracks.
logger
« Reply #3 on: March 13, 2007, 08:06:03 PM »
ok now I have an head gasket leak I guess this could be the power loss problem .  Oil every where gay
logger
« Reply #4 on: March 14, 2007, 06:59:51 AM »
b318isp
« Reply #5 on: March 14, 2007, 11:25:47 AM »
Quote from: logger;21249
Oil every where gay
You mean its pink its there? :p
