Author Topic: stock conrods boost levels?  (Read 4746 times)
bar73k
« on: February 22, 2008, 10:35:18 AM »
anybody out there who has pushed stock conrods in an m42 to breaking point?
im running 22psi and i have stock rods, im planning on pushing that upto 25psi
but im starting to worry about the rods....
i have been told they should handle 20psi, well i know for a fact they do, but how far can i keep pushing?
rob_e30
« Reply #1 on: February 22, 2008, 12:25:51 PM »
We've been as high as 27 but I'm not sure I'd recommend it.
beegeezy
« Reply #2 on: February 22, 2008, 08:06:51 PM »
More info on your setup?!
stereomotional
« Reply #3 on: February 23, 2008, 01:40:03 PM »
they are cast correct?  i personally wouldnt go over 15-18psi especially on stock CR (i hope you lowered it).
mkIV Jolf 1.8t (the DD)
beegeezy
« Reply #4 on: February 23, 2008, 09:06:04 PM »
I thought the rods are forged on m42s, the pistons are cast iirc.
rob_e30
« Reply #5 on: February 24, 2008, 09:03:47 PM »
Quote from: beegeezy;43377
If you mean me, here is a link...
http://www.r3vlimited.com/board/showthread.php?t=96456
bar73k
« Reply #6 on: February 26, 2008, 04:56:51 AM »
i have lowered the compression to 8.0:1 with forged pistons...
ill dial her up to 25psi, we'll see how she holds up i guess
nuvolarossa
« Reply #7 on: February 26, 2008, 05:34:16 AM »
Quote from: bar73k;43614
So you'll have stock rods with forged pistons at 25psi? What headgasket you have now?
beegeezy
« Reply #8 on: February 26, 2008, 09:57:11 PM »
any idea on power output at that psi? And your car is noice rob :D
bar73k
« Reply #9 on: February 27, 2008, 01:58:42 AM »
Quote from: nuvolarossa;43617
heatgasket = cometic stainless steel
vatos_p
« Reply #10 on: March 17, 2008, 01:52:08 AM »
please give us some more info on pistons ( diameter and stuff ) and more info on gasket ( thickness )
i am planning to go to cometic gasket for pressure drop ( stock internals ) 9:1 so i can go to 0,8 - 0,9 bar press...so some more info would be good...
steer with the rear !!!
bar73k
« Reply #11 on: March 24, 2008, 03:08:20 AM »
the head gasket i believe i standard thickness, to be honest in not sure
and the pistons are custom made JE Pistons 8.0:1 comp
