Author Topic: Chain noise at ~3500 rpms  (Read 2946 times)
bimmerlover
« on: January 31, 2007, 09:35:14 AM »
Okay.. I'm really puzzled about this. As some of you might remember.. my timing chain slipped during the summer and busted my motor. I put an m44 in with all new timing related parts (chain, guides, tensioner etc.).
Somehow I still have a lot of chain noise as if there is some kind of interference/wear going on. I took the valve cover off and took a peek.. everything appears to be okay. The noise becomes very noticable around 3500 rpms. Anybody have any thoughts?
Thanks
Rachel
« Reply #1 on: January 31, 2007, 09:53:24 AM »
have you changed the tensioner?
Alpine003
« Reply #2 on: January 31, 2007, 11:16:33 AM »
Also, was everything torqued properly?
bimmerlover
« Reply #3 on: January 31, 2007, 01:20:06 PM »
Quote from: dude8383
Yes..
Quote from: bimmerlover
Quote from: Alpine003
Yep, sure was.
Any other ideas?
///Motorsport
« Reply #4 on: January 31, 2007, 01:21:59 PM »
I don't know.  But this makes me think, I've had predictable noise around this rpm, esp. partial throttle and decel, but figured it was somethign else.  I still hope its this shady heat shielding rattling around in the rear above the my muffler.
Febi Guibo
  • m42 reporter
« Reply #5 on: January 31, 2007, 04:39:22 PM »
Well... When i started losing oil pan bolts, i would get intermittent chain noise... Maybe check yer lower pan for bolts with an oil change?
Support M42club.com !!
sheepdog
  • Site Admin
« Reply #6 on: February 01, 2007, 01:22:38 AM »
Check the lower timing chain sprocket, I will bet it is worn and the chain is stretched. Mine was doing this with a new tensioner for a while before the chain started to break up.
