Nice engine... Looks familiar
Dont have a pic on my phone before the itbs but i did the valve cover copper, upper intake black, tb and afm copper 2 years ago.
Once i redo the fg plenum it will be copper and the itbs black.
To stay on topic i did the same job over the summer.
What a mess...
But once cleaned and reassembled. No leaks and no oil psi issues
Did you check if the oil pump bolts are tight or in the lower oil pan?
If you didn't change the timing cover gaskets yet... Its coming.. Mine went last month...
When that goes take the time and do both the upper and lower gaskets and water pump since you are there... Along with the chain guides etc.
Hope everything works out!
