Author Topic: Turbo valves  (Read 2505 times)
gtatbrissy
Turbo valves
« on: November 30, 2009, 05:27:57 AM »
Hi all,
I was thinking of a turbo built and in doing heaps of research it seems getting bigger intake and exhaust valves is the way to go. I wanted to know what options are out there, do I use valves from a different model or do I go after market.
Thanks guys!
dwtaylorpdx
Turbo valves
« Reply #1 on: November 30, 2009, 07:12:50 AM »
On our engines you would be best off investing in a really good (5 cut) valve job and a bit of light head work by a pro. There ain't a lot of room in there for bigger valves.
With a turbo build the yield for porting work is less than a na engine percentage wise. Boost is cheaper... ;) Unless your trying for some extreme 800 HP insanity... Then all bets are off.
Dave
gtatbrissy
Turbo valves
« Reply #2 on: December 01, 2009, 01:25:34 AM »
Any idea on who makes good valves?
nicknikolovski
Turbo valves
« Reply #3 on: December 01, 2009, 02:10:47 AM »
Yeap! Go to VAC Motorsports website, they got what you're after. http://www.vacmotorsports.com
gtatbrissy
Turbo valves
« Reply #4 on: December 01, 2009, 06:04:02 AM »
thanks nicknikolovski
