DISCUSSION
Swaps, Turbos, Buildups
328 injectors
Topic: 328 injectors (Read 2971 times)
92E36
328 injectors
September 02, 2009, 02:24:36 AM »
are 328i injectors a decent enough upgrade injector for a 318is turbo build. im not looking at going over 300hp.
bearsbmw
Sr. Member
328 injectors
September 02, 2009, 10:36:45 AM »
328 injectors are 22lb and for 12psi 30lb injectors are maxed out so you need atleas 36lb injectors
92E36
328 injectors
September 03, 2009, 03:26:52 AM »
could you recommend a alternative. If you could supply me with a name and or part number or what vehicle they are from. I am only going to be running 8psi
DISCUSSION
328 injectors
