Author Topic: e46 rear brakes upgrade  (Read 3064 times)
kote_alex
« on: August 19, 2009, 05:25:14 PM »
Ever since I had my e36 318is I wanted to have all-round vented rotors...
I went and bought from a salvage yard 2 calipers and 2 rotors from a 320i e46 saloon ...
I came over an interesting problem... I think the flexible hose that connects the caliper does not match the e46 caliper... my worry is that the e46 caliper has a larger whole than my e36 rubber hose...
Can someone prove me wrong ? :( Please do !!! :(
rob_e30
« Reply #1 on: August 19, 2009, 06:16:47 PM »
I don't know about that, I would not upgrade the rear brakes without a matching upgrade for the fronts.  You may throw the brake bias off and not get the expected behavior from your car.
kote_alex
« Reply #2 on: August 20, 2009, 01:29:13 AM »
okey, I get that, I've seen other projects like mine on other forums but they don't specify if the hoses match .... so ? anyone ?
ose30
« Reply #3 on: August 20, 2009, 02:58:41 AM »
Here you can find intresting stuff:
http://300mm.de/
kote_alex
« Reply #4 on: August 20, 2009, 04:19:19 AM »
it helped a bit ... saw that u could mount e46 328i calipers on 308mm rotors from 540i e34 ... but I didn't see nothing about the flexible hoses :|
ose30
« Reply #5 on: August 20, 2009, 06:36:58 AM »
Why don't you use the hose from a E46 you took the calipers? Metal piping is easy to modfiy to accept the hose if it is different.
kote_alex
« Reply #6 on: August 20, 2009, 08:34:22 AM »
that's a great idea ....
 now comes another question ... what size of 12 point socket, 3/4" do I need?
I feel it is a 32mm or 34 mm?
kote_alex
« Reply #7 on: August 24, 2009, 06:58:58 AM »
went through with the upgrade... and boy oh boy how good are my braking distances !!!
It was worth it ... everything fitted like a glove :D
