Author Topic: 92 318ic  (Read 9560 times)
AtlBMW
92 318ic
« Reply #15 on: August 18, 2009, 06:00:33 AM »
First of all, I am just figuring out this valance/spoiler/lip thing.
On this car, I believe the valance IS red and there is a plastic black spoiler of sorts mounted to it, that raps under somewhat.
I am looking for input on what and where it needs....
3bvert
92 318ic
« Reply #16 on: August 18, 2009, 02:44:18 PM »
soory, for some reason I have trouble thinking your whole valance is there, to me it just does not look right esp in the side shot
compare it to the side shot of the other red vert you posted
my 91 calnce looks like this, although ti has had a fight wiht a curb and lost its lip, both with po
crap , not enought posts to uplopad a pic I guess
but anyway
get a pic of your valance and post it so others can see and we can help more
AtlBMW
92 318ic
« Reply #17 on: August 18, 2009, 09:27:27 PM »
I'll try to get a better pic but in the mean time, perhaps this will help:
tony92ic
92 318ic
« Reply #18 on: August 19, 2009, 09:27:49 PM »
That front valance is all messed up.  It should have brake duct holes and foglights or at least blanks where the foglights should go.
That car looks like someone smashed up the valance. Then rather than repair it, they cut it off and attached a lower valance piece from a 1984 318i.
Note the white 1984 318i below. Yours should look like the silver 318is.
Big value deduction for that mess. Its not and easy fix.
Never mind. I can never get photos to upload to this site.  Do a google search. You'll see what i mean.
« Last Edit: August 19, 2009, 09:34:31 PM by tony92ic »
Tony
92 e30 318ic - Why I am here
72 2002tii - Much modified
91 M42 - Am I a hoarder?
AtlBMW
92 318ic
« Reply #19 on: August 20, 2009, 07:32:03 AM »
Googleing an 1984, I think that it may just be the 1984 set up..
« Last Edit: August 20, 2009, 07:34:17 AM by AtlBMW »
3bvert
92 318ic
« Reply #20 on: August 20, 2009, 11:46:11 AM »
just as I suspected
you dont have a valance, its gone, someone wacked it off
its not that big of a nghtmare, and I just sold a red one and a white one, so they are available. its about a 2 hour job, wiht one in hand, double the time, if you have to go pull one from the wrecking yard
or go with a nice aftermarket one
however, wht else is wrong , your probabally missing the brake ducts ( that go from the brake scoop in the valance to the fender splash), the temp sender, and of course fogs, do you have a fog switch next to yoru hedlight, if so, then you had fogs to begin with , rarely see a vert witho ut them
so buy a red one, and you will look good in one night
so if you want, spend some time, look at the front fenders and hood, they should have bmw stickers on them with numbers thta match the vin number of the car. ON the hood, its by the back roller, pass side,  on the fenders, they are on top , where the fenders bolt on, in the vacinity ( in line with  the afm, and the washer bottle), . if they are missing or say DOT and not the vin numbers, they are replacemnet, and the car has had more done to it then you were told, thus the wacking of the valance
« Last Edit: August 20, 2009, 11:51:49 AM by 3bvert »
AtlBMW
92 318ic
« Reply #21 on: August 20, 2009, 02:03:18 PM »
Thanks, good points.
What can I expect to pay for the proper valence and lip?
