Author Topic: M42 idle issue. help!  (Read 18959 times)
BlueBMW
M42 idle issue and gunk in the intake
« Reply #45 on: January 30, 2010, 08:54:09 AM »
Its possibly your cat might be stopped up.  My car currently has no cat, but I cant stand the smell when I get out of the car (smells like an old chevy or something)  Seems like you can get a universal fit catalytic converter for about $70.
iamcreepingdeath
« Reply #46 on: February 08, 2010, 10:59:42 PM »
ok dudes I have an update.
I went to a junkyard, found a stripped M42 sitting in the dirt next to a gutted 1991 318i, and the ICV was still dangling there on a severed hose, so I swiped it, paid about $8 for it on the front desk, slapped it in my 318is, and BAM!  issue resolved!  it now starts flawlessly without a single shudder on brutal sub-zero mornings!
So easy!  it just needed another ICV.  I have just been too lazy/broke to buy one, but $8 is hard to beat!  the junkyard btw is upullandpay.com.  check it out.
dkbmxer002
« Reply #47 on: February 09, 2010, 12:00:57 PM »
hmm i have the exact same issue as you but along with it my gauge won't work. i am thinking i have the same issue, can you post a picture of the icv? i am about to clean it if i find it and i guess maybe my temp sensor is bad so i am gonna try and swap one from another motor because they appear to have the same part #
Frank Gallegos
« Reply #48 on: July 17, 2010, 03:11:56 AM »
told ya
longtallsally
« Reply #49 on: July 20, 2010, 04:44:37 AM »
This is a good thread.  I've not worked my way to the motor- yet- in my restoration, but I get this from time to time.
191k on the clock, and perfect starts and everything no matter the temp outside.  However, if I use the AC, drive for a while, shut the car down for even a few minutes, it starts right up, but idles like total crap for a few seconds.  I am very particular about shutting off the radio and HVAC prior to shutting down the motor.
I have thought I just have an intake leak somewhere, but I also think I might have a sticky (despite being brand friggin' new) AC compressor clutch.  My O2 sensor is more or less in spec.
Nothing really to add, but I wanted to mention a couple things for someone searching on this issue.
colin86325
« Reply #50 on: July 20, 2010, 10:28:26 PM »
I think the M42 uses a stepper motor ICV vs the earlier Motronic units that use a plunger style system. When powered down typically the stepper remains in its last position, whereas the plungers return to the position of least pressure.
longtallsally
« Reply #51 on: July 21, 2010, 03:08:51 AM »
Quote from: colin86325;94783
Makes sense.  So in other words, nothing I can do?
Hodge
« Reply #52 on: July 21, 2010, 12:32:32 PM »
I believe my ICV is fried as well. I did work on the E36 a few days ago and when I was done the idle was horrid. I tried cleaning the ICV out again today but to no such luck with the idle.
I took the screw for the throttle plate out and happened to have a screw that was the same only longer so I screwed it in and set the idle to about 950rpm with the A/C on. With A/C on before it was about 450rpm and if I gave it gas it would die if I let the throttle pedal out.
Without A/C the idle is about 1000rpm which is where I have wanted it for awhile anyway. I get alot of flywheel/clutch chatter(especially with A/C) and at that idle speed there is virtually none.
I figured it was the ICV because the engine would rev and run perfectly fine otherwise. If I was driving with A/C on and let off the gas the engine would die (clutch disengaged). It would bog to about 450rpm without the A/C.
1995 E36 318isc
