Author Topic: New to BMW, e36 Power loss  (Read 2933 times)
Windsma
« on: June 28, 2009, 09:40:59 PM »
Sometimes at WOT it is very sluggish. Half throttle will have more power.
I bought the car a few weeks ago and am working out little bugs. (suspension, electronics etc..)
I have yet to give it a tune up bc i was waiting on a few other parts.
I now have new gaskets for the Oil filter and valve cover and am ready to tackle it.
Where should I start to get the most out of this engine?
Im a decent mechanic and think w/ 200k miles on it, its time for a good TB cleaning.
Recent cars were Chevy's and Mitsubishi 3000gt
94 318is coupe m42 200k miles 5spd.
« Last Edit: June 28, 2009, 09:44:23 PM by Windsma »
94 318is 5spd 200k
« Reply #1 on: June 29, 2009, 07:04:53 AM »
I'd start with the throttle body sensor, there's a copy of the e36 Bentley in the Reference section for tests.  Test the usual culprits...AFM or O2 sensors.  Vacuum leaks are also pretty common on these cars.
Windsma
« Reply #2 on: June 29, 2009, 04:17:12 PM »
I have the Bentley already. Ill have to look thru it better.
picked up some AutoLite Platinum spark plugs. Ive heard Bosh Plats. are bad. how are the autolites?
94 318is 5spd 200k
Windsma
« Reply #3 on: June 29, 2009, 07:20:46 PM »
The TB boot has been wrapped w/ electrical tape, and the hose connecting to the valve cover is loose.
I need to replace the boot and hose.
Replacing the plugs i found the old ones were Bosh Plats. 4 electrode.
94 318is 5spd 200k
« Reply #4 on: June 29, 2009, 07:33:40 PM »
I think the Bosch platinum +4 are the factory recommendation.  I use NGKs mostly, but the Bosch plugs aren't that bad either.
Definitely fix all the hoses.  I'd check them all very closely, a leak will really keep the engine from running as smoothly as it should.
Danny707
« Reply #5 on: June 29, 2009, 08:10:56 PM »
ONLY use NGKs
Windsma
« Reply #6 on: June 29, 2009, 08:42:10 PM »
I only use NGK's in my racecar.  http://i175.photobucket.com/albums/w144/windsma/777417-1.jpg
I love them.
but i got cheap today bc my ass still hurt from my sunroof repair cost.
« Last Edit: June 29, 2009, 08:45:15 PM by Windsma »
94 318is 5spd 200k
