Author Topic: Running Rich, codes 1222 and 1226, replaced many things  (Read 8632 times)
JoeDellio
« Reply #30 on: July 08, 2009, 04:09:20 PM »
Well, Im pretty sure the head gasket is toast or my head is cracked. Today I filled it up in the morning, took a half gallon, then I drove it for 15 minutes and checked it again when it cooled down. It took another half gallon.
It use to loosed about an inch before I drove it up to OH from FL. But the bars leak I put in must have cured it. It wasnt till I seafoamed it that it started loosing coolant again massively.
I have no oil in my coolant or vice versa, but when I get on it or rev it up high it does puff white, and there is condensation in my tailpipe. With my exhaust leaks I could be purging it out also, or dripping it from all the holes in my muffler. Thats why Im thinking cracked head, or a leak in a galley that isnt letting the 2 fluids mix.
Tonight Im going and buying a leak tester and putting it to it. Im hoping this is what plagued all my other problems. Water getting in my combustion, wetting the plugs, not burning all the fuel and in turn running rich. Is that to crazy of a diagnosis to make?
[SIGPIC][/SIGPIC]1995 318i
JoeDellio
« Reply #31 on: July 13, 2009, 03:27:37 PM »
Im going to make my own CCV that pulls more vacuum.
Im thinking my higher than normal CC pressure is messing up the CCV and screwing up my readings on the O2, in turn making my car run RICH. Which is my main problem.
