Author Topic: Finally--Electric fan  (Read 15388 times)
1991 E30 M42
« Reply #15 on: June 03, 2009, 01:47:24 PM »
Quote from: Jimmy Lewis;72889
Looks great, I need to do this badly. Maybe I will swing by the junkyard tomorrow and try to get something rolling. Eric you game for helping me wire it?
Yeah, I'm game, I think one good arm and one bum arm can do it
« Reply #16 on: June 03, 2009, 08:43:54 PM »
Quote from: Nimble;72962
What about just wiring it to a in cabin on/off switch?  How hard would it be to just flip the switch when you see the temp hit halfway?  I'd *much* prefer this so I have total control.  Besides, it would give me something to do. ;)
You only need to forget once to have a really bad day. I can switch on my cooling fan manually by hitting the AC button. I usually end up switching on the AC before the engine needs the extra air flow of the fan. But once in a while the temp switch kicks in the fan without me noticing.
« Last Edit: June 03, 2009, 08:45:58 PM by tjts1 »
RidingSimple
« Reply #17 on: June 03, 2009, 10:34:39 PM »
^Good point.
I check my temp guage constantly though, impossible for me to forget as my peripheral vision would catch the temp rise.  Living in Hawaii, where it's 85 everyday I tend to pay attention to the guage more than most.
B318M42W
« Reply #18 on: June 04, 2009, 10:39:24 AM »
an a side note... an alternator from an E36 will fit and gives out 105A. ( don't remember year though)
M90 Blown M42 :cool:
KenC
« Reply #19 on: June 04, 2009, 07:08:32 PM »
I changed to the 80/88C temp switch, added two bottles of water wetter, and just yanked the whole clutch fan.  I'm running only the stock aux fan.  It kicks on when the temp gets a tad above 1/2.  Even in stop and go with the A/C on full, it has never been up to 3/4 on the temp gauge.
« Reply #20 on: June 04, 2009, 08:50:05 PM »
I'm tempted to do the water wetter too.  I did that on my e34m20 and it's worked like a charm.  The temperature on the m42 isn't stable like the m20 though, maybe a leak or two that I have to cure before I go all fan delete-delete.
AcSchnitzer318is
« Reply #21 on: June 07, 2009, 07:38:39 PM »
Quote from: tjts1;72956
Were you having an issue with the temperature switch or did you replace it with the 318ti one? Mine turns on somewhere between 1/2-3/4 but it seems to work just fine. like that.
Nope nothing was ever wrong with that switch... I just never let it get high enough to have it switch on by itself.  It switches on just before the 3/4 mark which seems fine to me.  And we have 100 degree days almost every day now.
DLag30
« Reply #22 on: June 20, 2009, 02:44:50 AM »
can anyone explain to me how the wiring is on this set-up?
thanks
Wizard
« Reply #23 on: June 20, 2009, 07:23:59 AM »
Quote from: DLag30;73944
thanks
You talking about my set-up?
DLag30
« Reply #24 on: June 20, 2009, 09:39:39 PM »
^Yup. I always wanted to do this, but the wiring always scared me..
JP 91iS
« Reply #25 on: June 21, 2009, 01:34:14 PM »
Quote from: DLag30;73976
I wired up mine differently than Wizard and it was not scary.
http://www.m42club.com/forums/showpost.php?p=73440&postcount=2
-JP
Project M42: generating funds
Wizard
« Reply #26 on: June 21, 2009, 09:01:54 PM »
I have to go to New York for a few days, but will do a write-up when I get back...Wiring is fairly straight forward though..
DLag30
« Reply #27 on: June 21, 2009, 09:52:03 PM »
Quote from: JP 91iS;74013
Hey, thanks for this! I'm still confused about using the volvo relay.(sorry, I am very bad with wiring):D
DLag30
« Reply #28 on: June 26, 2009, 09:20:51 PM »
btw, can I use a aftermarket pusher fan instead(summit)?
« Reply #29 on: June 26, 2009, 11:53:25 PM »
You can but you already have a pusher fan in the car.
