Author Topic: Miller Performance W.A.R.  (Read 31649 times)
« Reply #60 on: April 19, 2012, 05:58:00 PM »
Later M42 DMEs also have EWS, from mid-95 onward IIRC.  But that can be defeated by cutting a wire from the EWS control unit and a bit of chipping, right?
bmwconnect
« Reply #61 on: April 19, 2012, 06:43:09 PM »
Quote from: DesktopDave;111981
1995 EWS equip M42 need's EWS delete chip to defeat it. ($100 for my EWS delete chip). Cuting a wire will not work.
All the best
Midnight YouTube Channel
« Reply #62 on: April 19, 2012, 06:55:01 PM »
Interesting. So BMW later switched to a wasted spark ignition regime on the M42, versus spark-per-cylinder? I know that the E30 M42 will go to wasted spark if the cam sensor stops functioning, but will do spark-per-cylinder otherwise. What is EWS? "Electronic wasted spark"?
What changed in the trigger wheel? Are you referring to the 60-2 tooth wheel on the crank, or the cam sensor? I know that the M44 used a different wheel on the cam.
bmwconnect
« Reply #63 on: April 19, 2012, 07:51:18 PM »
Quote from: bmwman91;111984
Ya the E36 M42 spark unit is just one big block of glue and 4 wires lol.  EWS or IMMO is the immobilizer to prevent theft.  I believe the tooth amount changed (don't quote me on that) on the E36. The spark conversion formula went from fac .75  offset -22.5 to factor .75 offset -45 on the E36 M42
All the best
PFCRayB
« Reply #64 on: April 19, 2012, 10:31:30 PM »
im in the process of rebuilding my turbo motor and was running stock management and just a rising rate fpu, so i am looking for a alternative to running a ms set up, so if you have anything that i can run a few different maps like the war chip then let me know
bmwconnect
« Reply #65 on: April 20, 2012, 08:27:00 AM »
Quote from: PFCRayB;111991
I have what you need. contact me at midnight-tuning@rogers.com
Thanks
GSBMW
« Reply #66 on: April 20, 2012, 11:00:21 PM »
Quote from: bmwconnect;112011
Thanks
Is this something that can do away with the AFM, and use an MAF in it's place? Also looking for something that can run the stock vehicle and later be configured for F/I
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #67 on: April 21, 2012, 06:43:21 PM »
You probably need a standalone for that :)
-Nick
91 E30 M42 with VEMS
« Reply #68 on: April 21, 2012, 07:56:04 PM »
Swapping to a MAF takes more than re-mapping the stock ECU firmware. You can get the car to run, but a tune will usually only be valid for one air temperature (or you can fool the ECU into thinking it is one temperature all the time, but that isn't really the right way either).
You either need to go stand-alone, or a microcontroller to translate mass flow rate to volumetric flow rate on-the-fly.
bmwconnect
« Reply #69 on: April 22, 2012, 09:46:11 AM »
Quote from: bmwman91;112048
well said :)
You don't need to swap to a MAF anyway to have a good solid running FI OBD1 M42
PFCRayB
« Reply #70 on: July 16, 2012, 08:42:49 PM »
can you give me more info on what you can do for me, i am going to be running a t3 turbo, on a party much stock everything else, excpt for head studs and mls gasket
Fastlanemotors
« Reply #71 on: July 19, 2012, 01:40:12 PM »
bump same setup build going on here i ned dme engine managemnt help
i wanna datalogg and learn myself just get me on the right route
