Author Topic: HELP!! 3rd BUSTED FUEL PUMP !  (Read 6276 times)
charlesmarseille
« Reply #15 on: April 16, 2009, 09:48:36 PM »
thanks, ill try that tomorrow and update. news to come.
B318M42W
« Reply #16 on: April 16, 2009, 10:01:33 PM »
oh... and did you have any drivability issues??? like lack of power, crappy idle, wierd engine acting/bucking, ect ect ect..???
M90 Blown M42 :cool:
charlesmarseille
« Reply #17 on: April 19, 2009, 03:41:30 PM »
ok update: i pushed compressed air in my fuel lines (both to the fuel rail and the return line) and some nasty grey white brown **** came out. so put some more fuel in it, started it with a new pump and VOILA! car runs. but runs okay lets say it that way, stalls from letting it go at 3000rpm and if i let go slowly it pops the check engine light. I turn off the car, stomp test, and I get 1252 (fuel injector num. 2). I just replaced the injectors, with the orings, checked voltage at all injectors and to all connectors, everything good. Would this happen if my gas is contaminated? cause i think theres some water in the tank (please, dont ask why!!:( )
Thanks b318m42w for your help, and other guys too. always a joy to come back on my pc and find new posts.
Charles
charlesmarseille
« Reply #18 on: April 28, 2009, 03:01:46 PM »
still have some hesitation at idle, and it sometimes dies. if there was water in the tank, would this be the good symptons for an non gas only tank?
nicknikolovski
« Reply #19 on: April 29, 2009, 05:47:06 AM »
How's your fuel pressure at the fuel rail? Is your fuel pressure regulator working correctly? To test it, run the engine at idle, disconnect the vacuum hose at the fpr. The idle speed should increase. Re-fit the hose, the idle should stabilise. Check this out to rule it out. Then check your injector harness. Are you sure you connected them in the correct way? Also check vacuum lines (need intake manifold off for this)
Then going back your original post above you said
Quote
check engine light sends the code 1215 (airflow sensor) but i just replaced the intake elbow, and did the throttle body hoses delete mod+ changed all intake gaskets. 2nd problem(but less important): my engine does a wastegate-like sound when reving, it seems to be an intake sound, but only when im rolling. anyways, what do you guys think of that?
Code 1215 (airflow sensor) this indicates that there is something wrong in the inlet circuit. I would test your airflow meter. On the M42 engine, the airflow meter (forward of the airbox, and behind the intake bellow), gives the engine ECU the signal for air mass entering the engine and also air temperature to determine air density so it can direct the injectors to spray the right amount of fuel. If the airflow meter is faulty, your engine will start but cut out immediately or even at higher RPM if you let the engine come back down to idle it could appear as if it may stall. The engine will not run without this signal.
Going off the E36 Bentley manual, test the airflow meter like so,
First check voltage - peel back the harness boot from the airflow connector. Find your pins, looking from the drivers side front wheel fender they should appear like so:
                4
         5           3
             Blank
      Blank         2
Turn on the ignition key, then check for approx 5V between terminal 1 and ground (earth). Turn off the ignition. If voltage is very low or absent, check wiring from airflow to ECM.
Next test, check the airflow meter itself.
Take off the intake boot, connect multimeter (in ohms setting), between terminal 1 & 2.
Swing vane inside airflow meter through it's travel and watch the resistance. It should change steadily without interuption. If this checks out move onto next test.
Now check the Intake Air Temperature sensor which is integrated into the airflow meter. Connect multimeter (in ohms setting) to terminals 4 & 5. Check the resistance depending on air temperature. Compare your results to these references:
1. 14 +or- 2 degress F (-10 +or- 1 degree C) Resistance should be 7-11.6 Kilohms
2. 68 +or- 2 degress F (20 +or- 1 degree C) Resistance should be 2.1 - 2.9 Kilohms
3. 176 +or- 2 degrees F (80 +or- 1 degree C) Resistance should be 0.27-0.40 Kilohms
I know this is alot of info to absorb but do it step by step. For resistance checks you don't need the ignition on. For voltage checks you need ignition on. Good luck and I hope to see your results on how you went.
« Last Edit: April 29, 2009, 05:51:38 AM by nicknikolovski »
///eMveee
« Reply #20 on: May 03, 2009, 06:07:42 AM »
Quote from: charlesmarseille;70393
Charles
    POSSIBLE  contamination of fuel.   (not water,  Poss. sugar or soda)
I know this sounds weird but I had a 7 come into shop about 2 months ago with similar prob.  Took us forever to figure it out.  Pull fuel pump and look carefully into tank with flashlight.  Look at the bottom, fuel is lighter than warter and lighter than soda.  Fuel WILL float on top of these liquids.  Your pump sucks from the bottom of the tank it will suck up this crap.  Pump will also get clogged, explaining why the pump worked after u banged on it.  This car needed new pump, filter, injectors and fuel rail, we also sent the tank out to be cleaned.  Yours may not need all this.  We also got the same greenish/white powdery substance when we blew air in the fuel lines.
    Pull injector 2 out and see if there is any builbup/blockage  in the inlet
screen.  Good luck.   Hope this helps,  I don't meen to scare you :(
widebodye30
« Reply #21 on: May 08, 2009, 07:20:15 PM »
i had a similar problem mine turned out to be 1st torn filter sock 2nd clogged filter sock. i ended up buying a walbro 255 (can defintely tell its running, very loud), blowing out the lines and replacing the fuel filter ran like a top. Sad thing is shortly afterwards water pump failed, car over heated and cracked head. Just finished swapping a '95 ti motor (serpetine belt ftw electric fan ftw)and everthing seems to still work fine. Good luck
