Author Topic: Serious power gain mods... no joke!  (Read 6015 times)
dblmikeusa1
« Reply #15 on: February 25, 2009, 09:09:17 PM »
Quote from: halcrontech;67106
How about rebuilding your engine into a 2.1L with 12:1 compression and 88mm diesel crank. Install some aggressive cams and rev all the way to 9000 RPM with solid lifters and bigger valves etc. I am sure you will easily hit 200-250HP or more.
Got some real info on this???
xwill112x
« Reply #16 on: February 25, 2009, 09:23:24 PM »
not worth it.
you could m52/s52 swap your car for less than that, and god knows how much power you could pull from one of those motors to make the cost equivilent...cams, obd1 manifold, intake, exhaust, with a nice chip thats 250hp on the wheels.
24v swap ftw if you want some REAL power ;)
to reitterate in more simple terms, m42 is a great DD motor, a little peppy up top, but it's not a "powerful motor".. your not going to see a big jump in power unless you drop some serious $, or you boost the shit..ALOT.
Ich liebe meinen E30
AcSchnitzer318is
« Reply #17 on: February 26, 2009, 01:44:43 AM »
^Agreed... plan to throw 7lbs on mine just to make it more fun, not really "powerful".  But here's the 5 I did (so far)... dyno'd at 135.4 to the wheels on the dyno...
1. Ebay chip (proformance)
2. 19lb 4 pintle injectors
3. Deleted parasitic fan, installed electric (volvo)
4. NGK Iridium plugs
5. All new vacuum hoses, deleted TB heater plate
Selfish
« Reply #18 on: February 28, 2009, 11:42:29 PM »
what kind of CAIs have you guys installed? K&N? aFe? what were your results? Steer me away from a K&N set before I buy it if you have had better results somewhere else!
Danny707
« Reply #19 on: March 01, 2009, 12:33:23 AM »
KAMotors.
xwill112x
« Reply #20 on: March 01, 2009, 01:11:46 AM »
Quote from: Selfish;67400
aem dry-flow cone filter, helps with throttle response.
