Author Topic: code 1226 knock sensor #2  (Read 9589 times)
monty23psk
  • -Receive: 17
« Reply #15 on: March 03, 2009, 02:21:16 AM »
you can test the sensors with a multimeter and measure the ohms... I dont have the specs, but if you search for my username, it should come up. if you cant find it, let me know and I will search it. One of mine has 0, but the car would run ok, just sometimes the hot start would cause the car to turn off.
gene1219
    • http://www.gearworksmfg.com
« Reply #16 on: March 03, 2009, 04:01:50 PM »
Quote from: JoeDellio;67287
Installed O2 sensor. No changes. Gonna replace knock sensors.
I had the same 1226 code and bad loss of power once warmed up.  A new o2 sensor fixed my problem.
When was the last time your plugs were changed?  I wonder if a bad plug/wire may becausing a missfire affecting the knock sensor.
JoeDellio
« Reply #17 on: March 13, 2009, 10:12:43 PM »
Problem still exists. I have a nasty choppy/sounds like I have big cams idle, yet my tach needle stays steady right where it should. I was getting the 1226 code, then I replaced the O2 sensor and the code dissapeared but then 1222 popped up. Today I replaced both of my knock sensors, cleaned my IACV, and replaced my plugs and wires. Started car up and it still runs the same, but now the 1226 knock sensor 2 code is back. I dont know what the deal is. How can I clear the damn codes? Ive had the negative cable off for hours, and I heard when pulling codes if you hold the pedal down for 10 seconds the CEL will go off and it will clear, but I did this and it doesnt work.
Also when pulling codes will it only show 1 code or what? Mine will flash the same 1226 code over and over again, at least 10 times in a row, I get fed up and just turn it off instead of seeing if it will stop.
[SIGPIC][/SIGPIC]1995 318i
