Author Topic: My modded subframe  (Read 7169 times)
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
My modded subframe
« Reply #15 on: March 20, 2009, 03:07:38 AM »
Very impressive.
how did u decide on 17cm? why not more or less?
how did u calculated this?
WowMom
BTRA!
My modded subframe
« Reply #16 on: March 20, 2009, 09:20:33 AM »
Quote from: e30guydownunder;68599
I can tell you after putting the engine back in my race car you are going to have hell on your hands...the head will hit the battery box and all that folded junk, you are going to have to cut alot of steel unless you go dry sump and stand the motor upright.
good luck with it thou, keep us updated....lots of room for a turbo up front now!
looks like there is enough room to fit SEVERAL turbo's now!!!
HMS_Tim
My modded subframe
« Reply #17 on: March 24, 2009, 09:13:52 AM »
Quote from: robweenerpi;66369
Here's a couple from tonight's progress.
There is a lot of open space now.  I could probably stand between the radiator and engine when done.  But..there will probably be a large duct there.  :D
As you can see Cylinder 4 sits basically where the heater box was inside the firewall.
Nice.
Looks like you're beating me on my future plans!  Should move some weight back a little!  I'm not even sure I can move the motor back anymore.  I might be getting into a new scca class next year.  If I do the class I have to make my pinned aluminum skin doors hinge!  That should be a fun project!  It sucks I cut off my hinges on the body too...:(
Let us know what the car weighs on the scales and and what the front/ rear % is.
« Last Edit: March 24, 2009, 09:22:45 AM by HMS_Tim »
robweenerpi
My modded subframe
« Reply #18 on: August 18, 2009, 12:51:25 AM »
I think the car will be about 1850-1900# when done.  It's kinda sat for a few months now as I accumulated some parts and tools I needed to complete.
Car should be 50/50 evenish.  It was about 52% on the front with the engine in the stock position and the car gutted to 2200 pounds.  I will not be running a dash, bumpers, lights, and other parts.  I actually had the car running at 1950 pounds once with more parts on it than will be put back on.  My doors, trunk, hood, and lots of other parts have been skinned and modified.  But I'm adding several bars to the cage and gussets to make it safer since it was originally designed for spec.  There's even an M44 crank and rods sitting around here somewhere.  :-)
Quote
Very impressive.
It was how far back I thought I could go with an easy sub frame modification and easily fit the E36 style pans.  Just a metric measuring tape initially.  I just bolted a spare sub frame to one of my engines and roughed it out.  Then rounded to 17cm for shits and giggles.
Quote
I can tell you after putting the engine back in my race car you are going to have hell on your hands...the head will hit the battery box and all that folded junk, you are going to have to cut a lot of steel unless you go dry sump and stand the motor upright.
I smell what you are stepping in.  There was a lot more metal removed than what is pictured here.  I cut it out in little stages at I test fit with additional components.  It will use solid motor/trans mounts as well.
e30guydownunder
My modded subframe
« Reply #19 on: August 18, 2009, 08:40:48 AM »
MORE PICS :D
I wanna see moar.
I'm looking at moving my engine back about 70mm (just so it butts up against the firewall sort of thing. That way i won't have to mess with tailshafts either (6 Cylinder shafter is about 100mm shorter). Then I'm looking at modding the sump and rotating the engine a little bit to get more room for the turbo i wanna stick down the side of the block :D
