Author Topic: Weird Wipers  (Read 2980 times)
Ittybittybeemer
Weird Wipers
« on: January 28, 2009, 08:42:10 PM »
My 95 3181 has a strange wiper problem. the wipers will run at normal or double speed but not at the intermittent- in that position they run at normal speed. Washer works. But they do not turn off until the car is stopped and the ignition is off. Then they will park if they are in the switch off position. I have heard this may be the wiper module or the wiper motor. Any suggestions as to which to replace first- I hope it is the module...........
Ittybittybeemer
Weird Wiper Problem Solved
« Reply #1 on: February 03, 2009, 10:59:30 PM »
:)My would not stop wipers problem has been solved. Fault was a  malfunctioning Module (It is black with a blue plug end. Part number is 61.35-8 366 381.) but you don't get to see that till you get it out. It is cleverly stored under the dash and behind the glovebox. The screws for the removal of the airducts are obvious but one nut is underneath the glovebox light. With that out the whole glovebox assembly popped out. A module from a wrecker solved the problem. Some had thought it might be the wiper, but if the wiper will park, it is the module. Not sure why I was worried. It never rains in British Columbia.
