Hey guys, here's the most recent story of my little M42. I'm having trouble putting my finger on the issue. Here goes.
About 2 weeks ago on my way home from college my fuel pump decided to take a shit about 1/2 mile away from my house in a nice convenient spot to leave it overnight. The next day, I installed the new fuel pump and I was on my way. I drove the car to and from school a few times that week and everything seemed just fine. After those few days I decided to fill the car up because in the process of installing the new pump I somehow damaged the fuel sender. Got a new fuel sender from my buddy Eric and it worked like a charm. That night after filling the car up and installing the new fuel sender, I went out to go pick up some take-out and low and behold, the car wouldn't start.
I have ruled out just about everything there is to rule out in terms of getting these cars to start and run right. I think I have a pretty good knowledge of such and anything that I am not sure of Eric always has an answer for. The following are items that are commonly at fault that are known working.
-Ignition system works as it should, car gets spark on all cylinders and the plugs are brand new, wires are also only a few months old.
-Fuel pump is running, pumps fuel all the way to the hard line in front of the booster, just as it should.
-AFM checks out because the car can be run on starter fluid into the intake track.
-ECU has been swapped with no change, so that cannot be the issue.
-Fuel Pump relay is known to work and has been swapped with other known working units.
-No fuses have been blown and all fuses are as they should be.
-FPR was one of the first items I replaced when the issue arose, it is brand new.
-Injectors, do not fail in batches of 4 as far as I know
-Coils, also tend to not fail 4 at a time
Now onto things that I believe it could possibly be, I would love to hear anything else you guys have to say about this.
-Crank position sensor could be bad, I have access to a known working sensor, but if any of you know how to test it with a multimeter that would be great.
-Cam sensor, not sure if this would cause a no start issue, but I guess its a possibility, let me know.
So in short, the car is getting fuel to the rail and getting spark, so my only conclusion is that the injectors are not pulsing. Once I ruled out the ECU, I'm left with these damn sensors. What are your thoughts? Note: the engine is not hitting on a single cylinder, it simply is not getting fuel into the engine.
