I was looking for black and white wire and that is the only one I could find
Ok, put a splice in that wire you cut.
The wire we're talking about is in circled in this drawing.
No cutting required, the wire has simple push connectors.
In your case, I'm guessing you don't have a catalytic converter and the wire should be connected.
If you do have a catalytic converter, then disconnect the wire.
