Author Topic: Info needed for buildup M42/M44  (Read 12519 times)
Tonppa
« Reply #15 on: December 18, 2008, 05:23:29 AM »
I had 176hp@6720/ 203Nm@5800 with regrind cams, slightly ported head (only intake side), 10,8cr (wiseco pistons) and ebay chip.
Ebay chip and stock injectors caused "some" pinging and corroded head. :/
In my setup stock AFM restricts badly top end power.
Now putting m40b18 rods and pistons in for a turbo :)
E30 318tic -88
« Reply #16 on: December 18, 2008, 11:43:08 AM »
Quote from: Tonppa;63096
UUIIIIIII!!! in this case i am gonna hit the 200hp mark with my engine? :D
« Reply #17 on: December 18, 2008, 11:53:37 AM »
everything else stock? ... hmm... i have a big smile in my face right now..
DutchM42
« Reply #18 on: December 18, 2008, 12:18:42 PM »
LOL :)
Thanks for the replies so far. This winter I'll decide which components are the best for my needs.
Tonppa
« Reply #19 on: December 18, 2008, 02:26:59 PM »
Quote from: swiss318is;63129
Sorry, forgot PUG Mi16 intake valves. Those are plug n play.
Rest is stock.
Would have been few hp more by adjusting cams, but loose some from bottom end.
http://www.prospeedracing.net/
This thing has ~230hp with about same mods as mine has +stand alone & ITBs.
E30 318tic -88
nuvolarossa
« Reply #20 on: December 18, 2008, 03:59:04 PM »
aren't Mi16 34,5mm valves?
« Last Edit: December 18, 2008, 04:01:28 PM by nuvolarossa »
« Reply #21 on: December 18, 2008, 06:33:22 PM »
Quote from: Tonppa;63144
Rest is stock.
hm... why do you need peugeot valves? if they are plug n play.. do they have the same diameter? doesnt make a lot of sense... and if not you need some new valveseats...bigger job on your head!
what is so special about those valves?
do you guys think i am gonna have about 200hp with my configuration?.. would be amazing.. and about the stock ecu with chip.. i can easely change to a fully programmable ecu...
in this case... it would be no problem to make a s42 replica .. ~280hp!? it seems ways too easy to me..
