Author Topic: Ultimate budget build.  (Read 82512 times)
Danny707
« Reply #225 on: March 23, 2009, 12:24:38 AM »
Doubt it will spool by then. My turbo is smaller than that and spools at 3500 in first gear.
You'll probably be at ~3000-3500 in first gear as well, seems to be a staple on this motor.
AcSchnitzer318is
« Reply #226 on: March 23, 2009, 12:50:59 AM »
Oh well... as all m42 drivers know, the car spends most of it's life above 3000 anyway ;)
At least I know the turbo will work for the application now... shooting for a very modest 180hp to the wheels.  But I think that should feel awesome in this car as it's sitting at only 138rwhp now.
Deftones
« Reply #227 on: March 23, 2009, 06:08:35 AM »
Quote from: Danny707;68755
I did think about it, but because of my stand-alone megasquirt, I no longer have to.
That's basically what an RRFPR does. If I understand the question right that is.
Booster works fine. No worries about your english, I'm happy to help.
Thanks so much for your help! maybe when i will become enough crazy (think quite soon:D) i will start to make a turbo header myself!
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
Boosted E30
« Reply #228 on: March 23, 2009, 05:47:29 PM »
Quote from: Danny707;68762
Just a thought you can not gauge how quick your turbo spools by doing a pull in 1st gear there isnt enough load on the engine. if you want to see how quick it spools you should do a pull in 3rd or 4th from 2500rpm or less and then you will be able to get an accurate reading.
Danny707
« Reply #229 on: March 23, 2009, 06:55:29 PM »
Oh ok.
Will do.
Deftones
« Reply #230 on: March 29, 2009, 07:46:34 AM »
danny how do you think a T3 is? my friend got 2 in his garage, they were in a '90 audi 1.9 tdi, so i think with the smallest compressor, do you think it is too much big or should work?
1992 318is e36
1990 318is e30
Danny707
« Reply #231 on: March 29, 2009, 06:59:05 PM »
Go for it.
Should be alright.
Deftones
« Reply #232 on: April 01, 2009, 04:53:15 AM »
thanks danny, i'll get it for 50 euro, it seems in good conditions... however is a strange T3, it has a wastegate bolt on on the turbine, it's of an old golf 1.6 TD... now i will start building the manifold!
how's about your car?
1992 318is e36
1990 318is e30
Danny707
« Reply #233 on: April 23, 2009, 10:58:09 PM »
Dyno sheets.
The lighter is my shitty tune.
Final numbers were 166/166 at the wheels. Puts around 191 to the crank.
bearsbmw
« Reply #234 on: April 24, 2009, 12:13:09 AM »
How much PSI?
Danny707
« Reply #235 on: April 24, 2009, 12:19:33 AM »
Seven.
ludiagsm
« Reply #236 on: April 24, 2009, 02:26:29 AM »
you have to do more work , that power is very low for turbochargered m42
Danny707
« Reply #237 on: April 24, 2009, 11:43:34 PM »
Yes I know, its a daily driver.
I have a fairly restrictive exhaust and intercooler on it right now, also only running 7 psi as mentioned.
Danny707
« Reply #238 on: April 25, 2009, 12:00:39 AM »
Also, Comp tested today, #1: 225 #2: 220 #3: 215 #4: 225
With 5-7% leak down!
ludiagsm
« Reply #239 on: April 25, 2009, 08:10:47 AM »
the compresiion is not the reason try to tune your afr ratios  in boost to be 11,5-12 ,after that try with ignition advance +- and see what happen . That turbocharger is very smol but you must have 220+hp
