Author Topic: Cold start engine shakes and sputters  (Read 27420 times)
roundel318
« Reply #45 on: November 15, 2008, 03:40:29 PM »
Also, when you mentioned Relays, did that include the O2 sensor heater relay?
bearsbmw
« Reply #46 on: November 15, 2008, 03:41:16 PM »
Quote from: roundel318;60843
swaped working Horn relay for the 02 heater relay
TPS not connected would not let me start my car
roundel318
« Reply #47 on: November 15, 2008, 03:46:09 PM »
and the electrical from the o2 heater relay to the o2 sensor? (darn automotive wiring)
when I disconnected my TPS, my engine starts, barely, and rumbles and vibrates like yours does.
do you know what the "evaporative purge valve" is for?
bearsbmw
« Reply #48 on: November 15, 2008, 03:53:09 PM »
Quote from: roundel318;60845
Ya that has something to do with the Evap system for the fuel tank I think anyway.. Im prity sure the ECU has no control over this item but I will check bentley for ref
roundel318
« Reply #49 on: November 15, 2008, 03:56:51 PM »
I was checking the factory wiring documentation here....
Bentley manuals rock :)
The ECU seems to have control over the evap purge unit crap, at least from the diagram in this PDF.
the O2 sensor heater works, is its wiring messed up?
« Last Edit: November 15, 2008, 04:00:54 PM by roundel318 »
bearsbmw
« Reply #50 on: November 15, 2008, 04:00:39 PM »
Quote from: bearsbmw;60846
I take that back Evap valve is controled by ECU
roundel318
« Reply #51 on: November 15, 2008, 04:03:39 PM »
Agreed per my last post, not sure if it is causing the problem.
Beyond a few other ideas we have come up with, I think the most sensible thing would be to try a spare ECU.
Were you running a custom chip right now? did you try the stock one? I think I remember you saying you had a spare / factory chip.
Perhaps I was dreaming :P
bearsbmw
« Reply #52 on: November 15, 2008, 04:06:45 PM »
Ok anyone who has this problem ... remove the onboard computer the one in the dash below the cd and unplug it and start car and see what happens
roundel318
« Reply #53 on: November 15, 2008, 04:08:39 PM »
I am just curious, which OBC is this you are referring to?
below the cd?
bearsbmw
« Reply #54 on: November 15, 2008, 04:10:50 PM »
The onboard computer below your cd or tape deck.. remove and unplug
roundel318
« Reply #55 on: November 15, 2008, 04:11:32 PM »
Do you have a E30 or E36?
bearsbmw
« Reply #56 on: November 15, 2008, 04:12:10 PM »
e36
bearsbmw
« Reply #57 on: November 15, 2008, 04:13:26 PM »
sorry on e30s to right
roundel318
« Reply #58 on: November 15, 2008, 04:14:47 PM »
E30 here, my heat / vent controls are below the cd/radio slot.
Is this the normal multi button OBC you are referring to though?
The E36 probably has a 9 or 12 button or thereabouts?
Most M42 E30 cars have a simple OBC that just has a date/time(mem) and external temp sensor (mounted in the brake duct on the drivers side i believe) that does not have so many functions / tie into other systems.
roundel318
« Reply #59 on: November 15, 2008, 04:16:52 PM »
Your OBC probably takes info to calc mileage, range, etc?
It takes info from a host of other systems if so.
What sort of difference are you having with disconnecting yours?
Do you have a grounding problem?
:P
