what would a 5mm reduction in rod length yeild as far as compression goes on stock 10:5CR compression pistons, Looks like an 135mm early m50 non vanos motor would do it.
what engine are you speaking for? M42 has 10:1 CR stock with 140mm rods, if you put 5mm shorter rod in there you'll have a huge static compression drop, to reach something between 6,x:1 to 7,x:1, too low:eek: is not so simple as changing only the rods as you see
, but there are a lot of factors that change the compression ratio, to have an idea of which they are read the input fields in this compression ratio calculator
http://www.not2fast.com/turbo/compression/compression.shtml My mind speaks always for the best ipotetical engine build (and this is $$$), but if you want to lower the CR from 10:1 to 9 you can always put a thicker MLS headgasket and you're there until the engine will survive or until the thicker HG will survive:)... if you have some kind of respect for it will last long enough at low boost and with a right setup
for human DD power gains it's proven to be a good solution, but if you want to go over 300bhp with only that and with poor fuel/spark tuning you're in the wrong road, you'll melt all :p. keep in mind that if you open the engine it's not worth to rebuild it to factory specs, just as you're there you can change something even on a budget
Saying that the M42 internals in stock form can't be turboed is false too. Sure there is a limit, for sure it's a risk, but at low boost and with care it would ran just fine if the engine has not bad wear...
I'll do it for steps... starting with low boost until 10-12psi with MLS headgasket, with the money saved for internals spend more on ECU/standalone/fuel tuning thinking as a reusable thing for bigger boost. Then optimise the car (fine tuning) at that boost level with expandibility in mind so to have a great DD. Maybe you don't need more than that power and you'll stop at that stage
big power is not always faster
and think that the more you raise power the more you'll need to upgrade other parts in the car too... differential, gearbox, halfshafts, brakes, suspensions... all should handle the new power... if you want big power and poor handling go and buy a big displacement Mercedes Benz boat;)
I'm hijacking my own thread:confused:
