Author Topic: Idle Control Valve Pinout  (Read 3196 times)
SonomaGTLN2
« on: July 23, 2008, 11:26:31 AM »
Does anyone know what color wire corresponds to which terminal in the 2-way connector going to idle control valve?  The PO of this motor had the wires pulled out of the connector and I am trying to fix it. Thanks.
M42 Swap a success!...so far:rolleyes:
RED IS 91
« Reply #1 on: July 23, 2008, 06:22:44 PM »
according to the e36 manual
white/yellow go to #1
red/white go to #2
adam12hicks
« Reply #2 on: July 23, 2008, 07:59:34 PM »
Do you guys know if later M44 e36 ICVs will work the same as ours?  I have a good source for them but finding them for the M42 is not as easy.
Thanks!
2005 X5 3.0 (kid hauler)
nicknikolovski
« Reply #3 on: July 24, 2008, 04:24:21 AM »
According to Pelican Parts here are the part numbers
13-41-1-433-627-M14 - E30 318i/is/iC - M42 Engine (E30)
13-41-1-435-995-M14 - E36 318i/is/iC (thru 01/94) - M42 Engine (E36)
13-41-1-433-627-M14 - E36 318i/is/iC (02/94-1998) - M44 Engine (E36
The E30 M42 & E36 M44 seem to have the same part numbers so I would say yes, you can use them.
adam12hicks
« Reply #4 on: July 26, 2008, 03:08:54 PM »
Thanks for the reply... that's odd though that the 94+ 318s use the same part number as the e30s but the 91-94 use a different part.  I'll go do a little more looking.
Thanks!
