no, i was going to do this yesterday. the throttle positioning sensor is 180 degrees the wrong direction, forcing you to put it on upside down or backwards or whatever, basically the tps will hit the intake housing. There is a C-clip on the rotating arm of where the tps goes, and you may be able to rotate the piece back 180, but i didn't try this because i didn't have the time. As well, you may need a tinny bit longer vacuum line to your fpr, as the fpr fitting is straight intsead of having a 90 degree elbo on it.
