Author Topic: 318iS Drift/Track 'bandit' - daqqer  (Read 37507 times)
Malaise
daqqer 318iS
« Reply #45 on: May 26, 2009, 05:15:22 AM »
Quote from: daqqer;72432
Hahahaaa, yeah thats my lovely gf. <3
About car tho, updates (all done by suvi123):
*shortshifter
*steering wheel - position is now 6cm lower and therefore more vertical, also the locking mechanism has been removed for safety
*hydraulic handbrake
Pics of the steering wheel position and how you did it pleaaaaase... ? :cool:
More gf pics arealways welcome. :D
daqqer
daqqer 318iS
« Reply #46 on: May 27, 2009, 12:31:28 AM »
Quote from: Malaise;72435
Well suvi123 did that, so lets wait til he gets online and comments that. ;)
Wrong topic for gf pics. :D
daqqer
daqqer 318iS
« Reply #47 on: June 29, 2009, 02:51:18 AM »
Some pics of the progress...
Hopefully the car is going to be 8XX-something kg.
daqqer
daqqer 318iS
« Reply #48 on: July 10, 2009, 03:43:38 AM »
Works on the body. Not much to do after the lower window corners.
Car at the moment.
Ken
daqqer
daqqer 318iS
« Reply #49 on: July 27, 2009, 01:01:18 AM »
About some progress -
*Welded right window corner also
*Welded antenna hole shut
*All the sharp and unnessesary objects removed from interior
*Welded floor front corners
*Welded driver side skirt
Ken
daqqer
daqqer 318iS
« Reply #50 on: August 17, 2009, 03:44:32 AM »
Ken
daqqer
daqqer 318iS
« Reply #51 on: October 03, 2009, 08:27:18 AM »
Heres a little update -
* Custom rear shock mounts
* Custom gearknob Nismo style
Ken
daqqer
daqqer 318iS
« Reply #52 on: January 12, 2010, 07:00:03 PM »
WTB some stiff lowering springs... 80/60ish maybe... anyone got some ideas ?
Ken
DrBobOh
    • http://www.influxlab.com
daqqer 318iS
« Reply #53 on: January 13, 2010, 12:01:26 AM »
What are you painting the interior of your car with? Spray or Brush? Lookin good...
The Red Dragon V.3. 1991 318iS
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
LoveClub Member #23
daqqer
daqqer 318iS
« Reply #54 on: January 13, 2010, 12:28:32 AM »
Quote from: DrBobOh;84529
It was covered up and painted over with a paintgun with leftovers from allkinds of metallic colors that mixed into some nice gray/silver metallic. :)
Ken
daqqer
daqqer 318iS
« Reply #55 on: July 05, 2010, 03:43:57 PM »
I plan on putting it all together for the start of August... so heres some progress..
* new starter
* light flywheel (about 1/2 of the weight of the singlemass M42 flywheel)
* bigger clutch
* fast gearbox
* quicker steering rack
* very slow locked diff
* Removed the sunroofs ''double roof'' -
* Fiberglass hood -
* New location for coils -
So engine bay will look something like this (only missing radiator and intake) -
* Making some room -
* Cooling -
The cooling part is still missing an oilcooler and an electrical fan, and another hole in the front skirt tho. :P
Ken
daqqer
daqqer 318iS
« Reply #56 on: July 12, 2010, 03:31:14 PM »
Some progress on the car again ...
* Made rollcage blueprints
* Hood pins install
* Fasteners for bumper skins
* Gearbox and starter fitted
* Driveshaft and diff fitted
* ABS lines moded to fit non-ABS system
* Dashboard weight removal
* Blower engine cover weight removal and respray
Some pics also -
But thats nothing, because....
Ken
e30-86
daqqer 318iS
« Reply #57 on: July 26, 2010, 07:48:00 PM »
Quote from: daqqer;69385
Ok heres the final version of the intake.
Need to deal with vacuum, coolant and fuel hoses a bit, then i can install it.
hi dagger .
i am curious to know why the intake was modded in this way , with the blocked pipe coming out of the intake ???
awesome car you have.
daqqer
daqqer 318iS
« Reply #58 on: July 29, 2010, 04:48:22 AM »
Quote from: e30-86;94966
hi dagger .
Thanks. Heres the info about it, and it DOES work very nicely, i felt it right after the install -
''After the intake mixture (fuel and air mixture) enters a cylinder, the intake valve slams shut. In the stock manifold, the intake mixture starts to recoil off the back of the intake valve and back-flows up the intake runner to the plenum. But with a pulse chamber manifold, the intake mixture goes straight back into the pulse chamber because that is the path of least resistance. Next the mixture recoils off the back of the capped-off tube (the pulse chamber) and heads for the back of the intake valve ready to enter the engine when the intake valve opens. Since the intake mixture is ready to go into the cylinder, the cylinder filling is increased and the engine makes more power. From past Dyno testing, we can claim a 15% increase in midrange torque with this manifold.''
So heres a lil progress, no pics tho sorry ! :D -
* New brakelines (copper and rubber), they run from the interior throught the handbrake now;
* Suspension all fitted;
* Diff Powerflex mount;
* Exhaust got taped and reinstalled;
* Gear linkage modded and installed;
* Measured the rollcage dimensions again and ordered 10 more meters material;
* Electric fan install;
* Aluminium custom airbox;
While the car waits for rollcage we threw everything together (exept dash and windows) and tried it out a bit. Oh yeah it was also missing the exhausts last part, pretty noizy that way. :D Anyway it was awsome, the car has no grip at all and can easily be drifted til the end of 3rd gear. 4th gear i didnt have a chance to try yet... not so good roads there, and also bugs and insects start to hurt at that speed, hahahaha. :D
The car should be completed in a few days now. Then it will need some paint and a lot of cleaning.
Ken
« Last Edit: July 29, 2010, 04:52:55 AM by daqqer »
romkasponka
daqqer 318iS
« Reply #59 on: July 29, 2010, 10:11:12 AM »
Quote from: daqqer;95039
Ken
E36 gearbox + 4,45 rear axle? ;)
E30 318is M42
E36 318is M44
