Author Topic: 6 Button OBC - is it backlit?  (Read 8644 times)
JP 91iS
« Reply #15 on: June 16, 2009, 07:06:36 PM »
Quote from: Jorgeconrico;73741
Do these tiny bulbs come out of the black casing or is it one piece?
These are the one-piece kind - sort of like a christmas light bulb.  There are other bulbs in the dash that are sockets and the bulbs themselves can be replaced.
OBC/Instrument Cluster Bulb: 62111368299
Heater/Ashtray/Switches Bulb: 63217167000
-JP
Project M42: generating funds
« Reply #16 on: June 16, 2009, 09:09:31 PM »
I think they just slide out with that little white bit on the side...I'm currently swapping a 6-button for the 13, guess I should have checked.
Jorgeconrico
« Reply #17 on: June 16, 2009, 09:19:25 PM »
Hey Dave what are you doing with the 6 button.......:rolleyes:??
JP 91iS
« Reply #18 on: June 17, 2009, 10:04:52 AM »
Quote from: Jorgeconrico;73765
I've got a couple extras - if you want one send me a pm.
-JP
« Reply #19 on: June 17, 2009, 11:57:18 AM »
My 13-button isn't lighting...I must have trimmed off too many wires, or the bulbs are burned out.
Does anyone know offhand which wires should go to the 13 button besides the ones from the cluster?
JP 91iS
« Reply #20 on: June 17, 2009, 02:54:15 PM »
Quote from: DesktopDave;73787
Are you doing custom wiring?  The only wires going to the OBC should all be in one bundle with one green plug.
-JP
« Reply #21 on: June 17, 2009, 08:58:18 PM »
Quote from: JP 91iS;73789
No custom wiring...I pulled the harness from a parts car and trimmed the extra relay wires off.  It's  now only the ten or so wires going between the yellow and green connector.
JP 91iS
« Reply #22 on: June 18, 2009, 12:23:35 PM »
I think you may need some of the wires that run down to the power distribution box on the left side of the steering column beneath the dash.  If I recall correctly that is where the light gets its power from.  Check the electrical troubleshooting manual - I don't think it has the 13OBC wiring but the 6-button wiring should be similar.
-JP
« Reply #23 on: June 18, 2009, 01:07:31 PM »
Yeah...I'm sure you're right.  It'll have to wait for some serious spare time...I have to chase down a leak into the driver's footwell anyway; might as well add the 13-button to the cruise control & do it all at once...
 I just had a though...the 6-button has wires running off somewhere else...I'll bet they're similar.  I'll be matching up some colors and post results!
BlackBMWs
« Reply #24 on: September 26, 2009, 07:52:39 PM »
Quote from: DesktopDave;73840
How'd your cruise control and OBC upgrade go?  I'm collecting the parts to do the same.  Any gotchas?  Thanks!
BMWCCA# 160411
