M42 single mass VS M20 single mass conversion
Author Topic: M42 single mass VS M20 single mass conversion  (Read 97690 times)
« Reply #75 on: April 27, 2011, 06:25:01 PM »
Quote from: sbarton;103306
For some reason I cannot find any reference to a E21 or E30 323i.  Does anyone know the part number is for the 323i flywheel?  Or better yet, a link to one I can buy in the US.
-Scott
Scott, you'd be okay with the stock 325i TOB as well. I'm running this exact setup on my white 318i and haven't had a single problem.
cristimm
« Reply #76 on: May 20, 2011, 06:13:01 AM »
Quote from: DesktopDave;101942
How common are the M42 single mass flywheels?  I'm thinking that this is the best option, even though it's smaller in diameter.
It's very common. I estimate about 50% of the IS'es in europe do not have A/C and do have the single mass flywheel.
PumpItUp
anyone
« Reply #77 on: June 02, 2011, 06:22:18 AM »
I'm about to try this conversion. But where does the spacer go? The one that is on the m42 dual-mass flywheel which you take off by drilling through the rivets.. and then using on the m20 single mass setup.
Also, what transmission oil does everyone recommend again? :-)
NisseJärnet
« Reply #78 on: June 11, 2011, 07:12:13 AM »
Quote from: PumpItUp;104290
Easiest way:
M20 flywheel, mill down the engine side of the flywheel a bit to get clearence for oil pan
M20 starter
M20 flywheel bolts (dont forget the big spacer between the flywheel and bolts!)
M20 clutch
Done! (works 100% on single mass M42, not sure about dual mass)
-88 E30 325i M50 6spd turbo, 764whp
-89 E30 318i M42, 140hp COP conv. (E36 engine + gearbox, 3.73 188 diff)
-90 E30 318is M42 turbo, 240whp (sold)
http://www.youtube.com/nissejarnet
stillmatick
« Reply #79 on: June 11, 2011, 11:00:58 AM »
so much work to convert to single mass,rather just keep my dual mass.
« Reply #80 on: June 11, 2011, 01:19:34 PM »
The flywheel x-ref at RealOEM only includes one USA model...the early 318is until 3/90.  Here's the diagram.  Though it's likely a dealer-only item and smaller than the M20 unit, it's plug & play.  I have no need for the larger 228mm clutch though.
So I've been thinking about doing it with the M40 parts myself.  From what I've seen, the correct parts are:
21 21 1 223 569 (refurb clutch assembly - Pelican lists it for $138 before shipping & 20% BMW overseas order fees)
Here's a LUK kit for $104.
11 22 1 739 315 (single mass flywheel - Pelican lists that for $404.  I'd get it used, definitely)
Looks like Valeo finally released their dual-->single mass conversion kit too.  $739 is pretty steep, but it has all the goodies.  Google "DMF Conversion Kit" & you'll see if it's a good fit for you.  I've seen it for less, apparently it's the same kit for the M44 & M52 in the e36 & Z3.  Still, that's like what my car is worth...it's a tough decision. :rolleyes:
Needs short bolts too, and I'm not sure if the M43 fork, anti-rattle spring & TOB are the right ones though since they fit the e36 transmission.  The M40/M42/M43 with a single-mass flywheel was installed in all kinds of cars.  I'm thinking it should be pretty easy to come by.
« Last Edit: June 11, 2011, 01:49:02 PM by DesktopDave »
PumpItUp
« Reply #81 on: June 15, 2011, 03:57:33 AM »
Why would you get that Valeo junk kit for $739!? That's made for profiting off people about to buy a NEW OE dual-mass flywheel replacement, and figure this kit will save them some money.
Used e21 323i or e30 325i m20 flywheel = $10-100 used
87-91 325i starter used from junkyard = $30 ish or rebuilt for ~ $100
From 325i/is/ic (1987-91)
Pressure Plate, w/o dual-mass flywheel = $82
Clutch Disc, 228mm, w/o dual-mass flywheel = $107
Throw-out bearing from a 318i (1984-85), 318i/is/iC (1991), 325/e/es/i/is/iC/iX (1984-91), M3 (1987-91)
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=21-51-7-521-471-M38&catalog_description=Throw%20Out-Bearing%2C%20318i%20%281984-85%29%2C%20318i%2Fis%2FiC%20%281991%29%2C%20325%2Fe%2Fes%2Fi%2Fis%2FiC%2FiX%20%281984-91%29%2C%20M3%20%281987-91%29 or a e21 323i = $43 vs $71
or just get the clutch kit = $240
Plus the bolts, etc..
By the way, http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=11-22-1-739-315-BOE&catalog_description=Flywheel%2C%20E30%20318i%2Fis%2Fic%20%281990-91%20Only%29%20For%20cars%20without%20Dual%20Mass%20Flywheel
"Quantity in Stock: 1"
« Last Edit: June 15, 2011, 04:07:48 AM by PumpItUp »
« Reply #82 on: June 15, 2011, 09:40:10 AM »
IDK if I'd call Valeo "junk."  I've used they're stuff on occasion, seems well enough made. They're economical, though not up to the reputation of first class suppliers like Sachs/Bosch/Hella/etc.  I'm sure that could be found for less $$$ too.  I thought the dual-mass was a LuK-designed product?  I don't trust them yet.
I'm thinking this is a really good choice if you'd prefer that your mechanic installs it.  Clutch swaps aren't for everybody...It's a bolt-in kit, all new parts, with a warranty to boot.  Any reputable mechanic or dealer will put it in right the first time & likely stand behind their work.
That link you sent made me start thinking though...(never a good thing)...if the e28's use the same TOB, I'll bet the whole clutch would be similar.  Sure the e30's are more common, but if an e28 was a one-stop-shop for all the parts that might be even cheaper!
***edit*** remove that thought.  A new e28 flywheel by itself at Pelican is $840.  Ouch.  Looks like it's mostly the same as an early e30 M20 eta setup.
« Last Edit: June 15, 2011, 09:48:44 AM by DesktopDave »
stillmatick
« Reply #83 on: June 16, 2011, 06:50:51 AM »
i rather use Valeo "junk instead of conversion thing. gotta pay to play you know what im saying mannnnggg.
PumpItUp
« Reply #84 on: June 25, 2011, 04:19:28 AM »
I didn't mean Valeo is junk, just that kit :-)
You can get a brand new aluminium flywheel from JBR, Ireland Racing, etc for the m42 or m20 for $400-650. Sachs clutch kit is $200-240. That's almost the same total price as Valeo but much lighter. Or you could order an OE single-mass m42 flywheel for $400 (special order from Germany).
lqbanotxano
« Reply #85 on: September 16, 2011, 06:26:39 PM »
Does one have to ballance the flewheel after lightning it? Do flywheels come ballanced from the factory?
1993 318is 5sp / gen 3 Mustang injectors / Mark D 91/7000RPM / Z3 shifter / Ford O2 Sensor
romkasponka
« Reply #86 on: September 17, 2011, 03:15:09 PM »
Quote from: lqbanotxano;106716
Yes, they must be balaced and comes from factory balanced.
E30 318is M42
E36 318is M44
PumpItUp
« Reply #87 on: September 24, 2011, 10:25:20 PM »
I regret using e21 323 throw-out bearing on this conversion. Should of used 318/325 e30, saved ~$30 and had longer engagement which I like. Now if I put my foot on the clutch pedal while driving I burn the clutch.
« Last Edit: November 04, 2013, 09:50:31 PM by PumpItUp »
« Reply #88 on: September 26, 2011, 04:34:49 PM »
Why you would be riding the clutch pedal anyway? You're only really supposed to have your foot there for shifting...
Balkanac
« Reply #89 on: May 30, 2012, 08:52:51 PM »
i have done a similar thing, got an m40 flywheel and an m40 clutch kit, everything fitted fine. can you guys get an m40 flywheel over there? I think the non air con m42s in US came with a single mass flywheel
1991 BMW 318is E30 RED
