DISCUSSION
Exterior
E30 with Mini Cooper S rims??
Topic: E30 with Mini Cooper S rims?? (Read 4066 times)
AlpineRob
April 12, 2008, 03:00:52 PM »
i know they are 4x100s (16"s) but will the offset work appropriately without spacers? thanks
haledj
Sr. Member
April 14, 2008, 12:50:01 AM »
the hub bore is wrong
e30= 57.1 mm
mini= 56.1 mm
and the offset is wrong, would need large spacers
Buy M42 Coil On Plug conversion brackets!
[/SIZE]
AlpineRob
April 14, 2008, 09:07:46 AM »
thought so..too bad - thank you
haledj
Sr. Member
April 14, 2008, 06:46:19 PM »
I know, wouldn't it be awesome if they just bolted up. We would have so many new wheel options.
[/SIZE]
ClodKing
April 25, 2008, 05:07:15 PM »
Is there enough "meat" on the mini cooper rims to bore them out a bit??
I ask because we have machines at work that could very easily handle this job...
haledj
Sr. Member
Reply #5 on:
April 27, 2008, 06:01:57 PM »
it isnt reall worth it, because you would need to run a hucentric spacer, and you can just have that machined to 57.1 mm on the hub side and 56.1 on the wheel side
[/SIZE]
DISCUSSION
Exterior
