Author Topic: monty23psk  (Read 140874 times)
Re: monty23psk
« Reply #375 on: May 05, 2022, 12:06:39 AM »
Damn, that is nice! I am going to need to look into that.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #376 on: June 26, 2022, 09:16:18 PM »
So after almost 15 years and almost 100K miles, I decided to swap out my static Billy/H&R combo for something adjustable. Went with Koni Sports and GC kit.
The old and new shock. I have AKG rear shock mounts the insert is still very good as it is only a few years old and not much mileage. I set the shot to a quarter turn before stiffest rebound to try it out.
New shock all together:
Old OE Sports vs GC adjuster and  Eibach spring. This is lowest setting to demonstrate but I have set it to something between HR race and sports
Springs and adjuster installed:
« Last Edit: June 26, 2022, 09:18:59 PM by monty23psk »
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #377 on: July 05, 2022, 03:18:25 PM »
Found the passenger side engine mount head shield cracked and a little rusty. Ordered a new plate and bolt.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #378 on: July 10, 2022, 12:14:45 AM »
Purchased a new headlight button with a fresh stencil. I will keep the old one and remove all the old grime, remove stencil and apply a new one in the future.
Before:
After:
Re: monty23psk
« Reply #379 on: July 13, 2022, 11:36:45 PM »
Good progress! It is always nice to see the little details getting refreshed...some of that stuff is getting hard to find, and certainly not any cheaper as time goes on.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #380 on: July 14, 2022, 04:25:22 PM »
Very true, if you bought sought after parts 2 years ago, you will make $ and if they are now NLA, you double. Not saying to invest in car parts but part of me wants to, lol
Re: monty23psk
« Reply #381 on: July 15, 2022, 11:25:51 PM »
Haha, E30 parts to the moon!
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #382 on: July 23, 2022, 08:23:20 PM »
I found out I was missing a small trim piece in the trunk. BMW still has it and very cheap. The car jack hinge has a cover on the right side.
The part:
Before:
After:
Re: monty23psk
« Reply #383 on: July 26, 2022, 09:14:01 PM »
Awesome find! Was this the product of a late-night adventure through the corners of RealOEM?
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #384 on: July 27, 2022, 04:46:48 PM »
LOL. It was a few years ago but was NLA. I checked a few weeks back and was available and very cheap.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #385 on: January 18, 2023, 08:33:35 PM »
Minor update, decided to swap out 30yr plus lug bolts with new ones.
New lug bolts:
Before:
After:
Re: monty23psk
« Reply #386 on: January 26, 2023, 10:16:21 PM »
Mmmmm 5-lug...jealous!
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #387 on: February 07, 2023, 10:20:21 PM »
Small update. The water tight connectors for the brake fluid level sensor were brittle and the plastic jackets were all gone. Every time I washed my engine bay, the light in the cluster would go on until it dried. I got a new housing and spliced in new BMW watertight terminals. My original housing was cracked so I bought a new one. Even thought the PN is new, it is now longer, and my assumption is that you do not need the grommet at the end. I reused the grommet because mine was intact.
Old vs New
New WT connectors in new housing
Installed:
Here I replace the housing on the windshield washer pump. The clips had broken off over time being the original connector. New on top of old.
Re: monty23psk
« Reply #388 on: February 20, 2023, 11:41:18 PM »
Wow nice...got a PN for that brake fluid level sensor connector? Mine is rotted out as well.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #389 on: February 21, 2023, 07:59:14 PM »
housing: 61131378408
wiring (WT connector): 61130007441 or 61130007442 (thicker gauge) Both seem to be NLA or back ordered.
