Author Topic: monty23psk  (Read 140846 times)
Re: monty23psk
« Reply #315 on: February 04, 2020, 05:55:40 PM »
This thread continues to amaze!
If you find a decent alternative to PB, LMK. Imgur has good reviews but didn't 'feel' right for me.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #316 on: February 07, 2020, 09:05:38 PM »
Flickr seems to work just fine for me and any of the new photos.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #317 on: June 13, 2020, 10:10:13 PM »
A small quarantine update. I have notice that my battery is not holding a charger after 48 hours. I only have a 43mA draw with everything connected, so I know I am within specs. But batter is now 2 years old and lower Bosch model. I would love a yellow top from Optima, H6 model but $ and while I know I can get a replacement at no cost at Pepboys, I decided to try using a battery tender. I will be out of town for a few weeks so just have the battery topped off is not a bad idea. After many night doing reading reviews, I settled on the CTECK MXS 5.0. All the top brand vehicles owner use them and even Jay Leno raved about them. I got it from Amazon installed it. With trunk in the rear, and the trunk organizer, I want to leave the lead connected all the time. This model has the plug which is fused and it has a cover to prevent anything touching the contacts. Nice quality. They also sell a 25ft extension which I might use if I want to mount the tender to the wall. I ran the connecter through the small hole int he carpet trim that is used to access the fuel door lock release.
Here is the device:
20200613_224614 by Alexander Montoya, on Flickr
Here is trunk organizer moved out of the way to show the connector lead connect to the tender:
20200613_225006 by Alexander Montoya, on Flickr
Nick_318is
  • -Receive: 11
Re: monty23psk
« Reply #318 on: June 16, 2020, 06:51:46 AM »
These ctek tenders are great, I use one on mine every winter.
Re: monty23psk
« Reply #319 on: June 18, 2020, 06:32:23 PM »
I'll check out the CTEK, my current unit isn't cutting the mustard. I usually use the cheap HF solar unit, but I only get a few years out of them.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #320 on: June 21, 2020, 09:51:04 AM »
I found out something yesterday. Today, BMW sells a charger, it looks to be a rebranded CTEK version. So besides reading Porsche and Corvette owners use it, BMW just outright sells it. Just the back and device says BMW. Save yourself $ and get it from Amazon, ~$40 savings.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #321 on: July 18, 2020, 10:42:10 PM »
Decided to refresh all the fuses after getting my battery tender. I ordered fuses from BMW. I had some from ECS and can confirm that BMW are the same. BMW originally used Pudenz branded fuses and this company has been bought by Littelfuse. They are branded Littefuse. I went with BMW as they were cheaper with my contact and are exactly the same.
Fuses:
20200718_225005 by Alexander Montoya, on Flickr
Before:
20200718_225603 by Alexander Montoya, on Flickr
After:
20200718_230322 by Alexander Montoya, on Flickr
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #322 on: July 27, 2020, 10:02:34 PM »
Over on R3V, I saw a very sleek USB charger which included fast charging for the Android devices. My radio has a USB port but it is very slow and my cigarette lighter is not installed. I ordered it, arrived Monday and today installed it. Works great and went wit the 2 port option in case I have a passenger. I will relocate it to the hazard location so its more available to passenger when it redo my AC panel. Still trying to source one as mine is missing a chunk under the AC switch. Got it from Falk MFG based in Oregon.
20200727_220100 by monty23psk, on Flickr
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #323 on: August 14, 2020, 10:24:28 PM »
For those following along, I have noticed when I drive the car, a slight hesitation, once in a while. As well, the car would turn off while taking off maybe 1 in 15 drives. Not my daily anymore, so this is over a span of 3 months. Also, while driving and if I caught it, the check engine light will flicker lightly. I decide to check my Bremi coil packs and cylinder 2 was odd. It would never give me .8 ohms as the other 3, but hover between .9 and .11, sometimes 0. When I look at the pins on the coil, terminal 1 has slight corrosion and mostly at the base. Then looked at the connector, and same white residue. Other pins were just fine. I received a new Bremi coil, connector with 3 open barrel double leaf terminals from BMW, crimped them on and so far so good. Will need to take it out for a few more spirited drives to make sure.
Thought I would share in case someone is noticing this on their vehicle.  Also, with now doing this, I will be shorting all the wiring, as I had planned many years ago, so I don't have to use cable ties to keep it somewhat organized. I know recently, someone used the e90 coil packs so maybe I will go that route. I do want to modify the plate so I can get the old BMW cover back on for a more stock look. Will be my next quarantine project.
20200814_231913 by , on Flickr
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #324 on: September 04, 2020, 11:01:19 PM »
Another project I was able to wrap up. After I upgraded my sub in the trunk, the JL Audio amp was not as powerful for the JL Audio sub enclosure. I upgraded to the MX series amp from JL Audio as they are used for extreme type vehicles as they are IP rated casings. I really liked the smaller foot print as they are used on boats and smaller vehicles like golf carts. I swapped the 250w for the 500w model and very happy with it. Sold the older one to pay almost half of this new one. I also upgrade my fuse distribution box and went with 4 AWG wiring. Here is a picture of the new board, wrapped in a nice thick carpet (while it stated black/charcoal, it is lighter compared to the BMW trunk carpets. The rear speakers are not connected (you can see the loose cables) as I got some BMW rear speaker pods that I will install to reduce the size of speakers in the rear. While driving, the rear speakers don't really do much for the listening experience. I also was thinking of mounting the sub box, but like the ability to move it or remove it, if needed. It is very heavy, so won't move around.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #325 on: September 22, 2020, 08:49:05 PM »
Little sneak peek of the before pics. e28 M5 wheels 5x120 et20 for the e30 heading to a certain place for new look....
20200922_183847 by
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #326 on: October 14, 2020, 11:50:24 AM »
A little progress during my visit at powder coaters. 1st color done. It is the closes to nogaro silver from the powder brand.
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #327 on: October 23, 2020, 11:18:19 PM »
Got the wheels back and so nice and shiny and smooth. The two tone came out very nice and subtle. Here is the one wheel with tire mounted before going on the car. If you you compart the lip to the center you can see the slight difference between the nogaro gray and silver lip (look at 7 o'clock position on the wheel face)
20201020_155409
I then took advantage to wash the gloss back powdercoated calipers and paint the brake rotor surface with silver caliper paint to prevent some corrosion between the hub and wheel in the inside.
Before (front wheel example):
20201021_143308
After (rear wheel example):
20201023_155118
monty23psk
  • -Receive: 17
Re: monty23psk
« Reply #328 on: October 24, 2020, 01:40:39 PM »
Got them installed. Had to get gas so took impromptu pics of front wheels. Car needs a wash, very dusty from being in garage and still need to lower front a little to give it a better appearance with the H&R OE Sports. At least you can see the colors better outside and how it looks again the Brilliant Red (very faded) color.
[url=https://flic.kr/p/2jYK1Hq]
Nick_318is
  • -Receive: 11
Re: monty23psk
« Reply #329 on: October 24, 2020, 04:45:39 PM »
The wheels look great!
