Author Topic: Show Some Turbo M42 Support!  (Read 8218 times)
Ruger
« Reply #15 on: April 18, 2008, 01:24:44 AM »
Quote from: rob_e30;45859
Here's the deal...
We're entering our car in the Grassroots Motorsports Ultimate Track Car Challenge that will be held here on the West coast in June.  It's a by invitation event and the candidates are being screened by their CarDomain.com pages.
For those of you with questions on our turbo M42 powered BMW Club Racer, this is where the most complete information exists.
Check out the page over at CarDomain.com and please help rate the car (with a good rating) to increase our chances of being invited.
The link can be found here  http://www.cardomain.com/ride/2980038
More infomation on the GRM UTC is here:  http://www.cardomain.com/features/grm
Thanks!
Rob
Hi Rob
I will be building a turbo m42 in a street car over the next year or so. the goal is about 350-400hp.
What parts are you guys using in your m42? currently my parts list looks something like this
Block treated, re bored and re honed, acid cleaned etc etc
Argo rods (which are made locally in aus which is a bonus for me)
Custom pistons (thats a problem are there any off the shelf slugs available for these engines? im thinking about running maybe 15-17 psi and something fairly low comp would be best. 9.0:1?)
Balanced crank
Mostly standard but refreshed cylinder head with all new parts through out.
ARP Bolts used throughout
Custom grind turbo cams? are these needed? a close friend is a veteran engine builder and now a cam grinder im guessing he could sort this out but is it needed?
GT2871R on a custom manifold (right hand drive) and all the custom cooler and intake pipework to suit.
It already has a lightweight flywheel with e36 m3 240mm clutch
Other concerns are the gearbox and Diff. Can a built Getrag240 cope with that power and will the medium case 325i diff suffice?
What parts are you guys using and what power are you making at what boost pressure on your m42? Another local m42 turbo just ran a 12.5 at the drag strip on 14psi of boost but im not sure which parts he is using
kowalski
  • El\' Duder
« Reply #16 on: April 18, 2008, 02:54:04 AM »
JE makes pistons for the m42.
Sale:
Fore Sale Thread
rob_e30
« Reply #17 on: April 18, 2008, 08:33:08 AM »
If you're talking about power at the flywheel, you're going to need about 20psi to get there (depending of course on the dyno).  We've not done the headwork yet so it's tough to say exactly what gains you would get.  We're running a Getrag 260 but it's a bit of a funky match up as we had to rotate the tranny slightly.  An E36 tranny would probably be a better choice.  We have a low milage (less than 60K miles) E30 3.73LSD and it's shot.  Testing it with a torque wrench and it slips at around 50 ft-lbs instead of the 65 that's called for.  We're running about 13psi right now but about to tie it into the ECU for more flexibility.
kowalski
  • El\' Duder
« Reply #18 on: April 18, 2008, 01:46:39 PM »
Quote from: rob_e30;47426
have you looked at the obx diffs off ebay? any thoughts on them?
Sale:
Fore Sale Thread
rob_e30
« Reply #19 on: April 19, 2008, 08:58:01 AM »
I'm not familiar with them.  We're looking at a variable ramp, 3 clutch with polished gears from Diffs Online.
rob_e30
« Reply #20 on: April 23, 2008, 10:40:12 PM »
Just a few days left!  Keep the love coming, please.  It's a great place to show off your ride.
rob_e30
« Reply #21 on: April 28, 2008, 08:56:46 AM »
W're down to the final few days, and every vote counts!  If you have not voted or signed the log book, please do.
nuvolarossa
« Reply #22 on: April 28, 2008, 09:58:44 AM »
voted and signed the guestbook! good luck
rob_e30
« Reply #23 on: May 07, 2008, 11:26:07 AM »
We're in!  Thanks for the support!
318kid
« Reply #24 on: May 11, 2008, 01:15:10 AM »
Good Job! and Good Luck. Take some vids!
