Author Topic: Hey Fellas...Whats your HP???  (Read 12519 times)
Boyracer
    • http://www.jannousianen.net
« Reply #15 on: April 28, 2008, 03:28:16 AM »
Jolly good show frankie! :cool:
Did you dyno different chips? I think you had about 143 hp last summer with different chip?
Frankie
« Reply #16 on: April 28, 2008, 05:50:29 AM »
Actually it was 144 with stock chip ;)
First dyno result was 149 hp with "Benzino" chip (available you-know-where). I think that increase resulted from the cooler intake air due to the heater plate removal. Then I installed the X-treme -chip(?) and result was 153hp.
I actually felt the difference after I installed that chip and that was due to the increased torque within 1500-3400 rpm range.
Boyracer
« Reply #17 on: April 28, 2008, 03:32:31 PM »
Ok, I will try that TB heater plate bypass too tomorrow since my car seems to be destined warm weather track car and I do not have to worry about TB freezing :)
strypt
« Reply #18 on: April 29, 2008, 01:52:52 PM »
296 hp and 372 Nm at the wheels. About 330 hp and 420 Nm at the flywheel depending on estimated drivetrain losses. 1 bar of boost (14.5 psi). Turbo M42, 318is E30.
« Last Edit: May 01, 2008, 04:21:41 AM by strypt »
DRIFTM42CANO
« Reply #19 on: May 02, 2008, 08:06:03 PM »
Quote from: Frankie;47994
I just dynoed mine, 153 Hp and 190Nm
Mods: throttlebody heater removed, G-power cat-back, chip (cheap ebay chip, X-treme or something).
The dyno which was used, is accurate. Its used by rally and track cars.
I discussed with the dyn owner and his opinion was that those aftermarket CAI's are waste of time and money. They dynoed 6 (inc. KN, pipercross etc.) and the result was that original paper filter was best. The oil inthe filters will destroy the airmass meter.
well my intake is just like a 6cyl one i removed one of my horns and i dont put the oil on the cone i was thinkin bout wrappin the CAI pipin or usin a heat shield
but wats that TB mod? u got a DIY?
rob_e30
« Reply #20 on: May 02, 2008, 10:49:26 PM »
319 RWHP on a Dyno Dynamics.
Boyracer
« Reply #21 on: May 10, 2008, 10:27:34 AM »
Yay! Took the car to dyno first time ever, for me and for car :)
Peak power: 155.6 hp / 6200 rpm
Peak torque: 200 Nm / 4300 rpm
Dyno chart here:
http://www.flickr.com/photos/25412802@N07/2479989515/
Only mods are TB heater bypass and ebay chip. Rev limit seems to be 7300 instead of 7500 but that's ok, power is already going down.
I'm happy. Next phase will be regrind cams and chip for them, hopefully in one months time :)
ajatya2
« Reply #22 on: December 09, 2008, 02:07:58 PM »
94 E36 318is
Dyno-
whp-162.3
94\' E36 318is
« Reply #23 on: December 09, 2008, 02:24:36 PM »
Dynolicious says 118whp yet my 1/4 time say 16.31sec @ 88.1 mph on 87 octane.
Many modification, most of them to make the car slower apparently.
bearsbmw
« Reply #24 on: December 09, 2008, 03:45:25 PM »
Turbo e36 m42  187whp@8psi with RRFPR & no spark tune
ajatya2
« Reply #25 on: December 10, 2008, 01:35:08 PM »
some times i realy dont trust dynos, my buddy has a 400whp integra and he dynod it once and it was 130 whp?
94\' E36 318is
xwill112x
« Reply #26 on: December 10, 2008, 09:03:16 PM »
well no dyno sheets butttt....
aem dryflow cai-custom built of course..(idc what anyone says, it helped with power!)
no cat, 2.25 piping all the way back to a dynomax super turbo muffler
volvo 850 spark plug wires
need a mark d!!!
she'll tear the tires loose 1st, 2nd, and on occasion i can snatch some 3rd.
Ich liebe meinen E30
Asserti
« Reply #27 on: December 11, 2008, 03:22:38 AM »
still no MarkD chip dyno results? :(
[/URL]
1990s14
« Reply #28 on: January 01, 2009, 04:34:20 PM »
146 at the wheels:
L+B standard 1.8 bottom end with bigger valve cutouts) + some mild headwork + some 278 catcams (still on hydraulic lifters)+ a 3mm oversize T.Body + custom remap (AFM retained).
« Last Edit: January 01, 2009, 04:52:50 PM by 1990s14 »
bbarnumboy
« Reply #29 on: January 04, 2009, 02:17:45 PM »
117 whp bone stock i think. besides cone filter. 1993 318is  M42.....do you think i have a chip getting that result. i am not sure if it had one when i got it or now.
