Author Topic: My french 318is, clubsport style...  (Read 15047 times)
romkasponka
« Reply #15 on: February 15, 2008, 06:15:42 PM »
Quote from: supermaaneuh;42834
I'm confident about my choice, springs and shocks are in the same configuration as most of rallyemen choose regarding the type of roads we have in our region, and my car will be a street use car with some track days during the year...
Do they use these springs ratios on the BMW E30 or you will be the first?
E30 318is M42
E36 318is M44
S14MPower
« Reply #16 on: February 16, 2008, 12:46:34 AM »
Looks like this will turn out pretty nice. Can't wait to see the finished product.
supermaaneuh
« Reply #17 on: February 16, 2008, 02:18:07 AM »
Quote from: romkasponka;42849
I was speaking about M3 e30 Rallyemen owners so I won't be the first, I prefer choose setups (for suspension as for engine) which have been ever used and validated by the experience of professionnals
noticed that in our old country roads are usually as old as the country itself so suspension has to be adjustate with that factor.
Quote from: S14MPower;42866
thanks, difficult for me to wait too!!!
Gerontodrivingophile... old timer car driver addict!!!
Choking Hazard
« Reply #18 on: February 20, 2008, 06:23:22 PM »
You are absolutely correct that for bumpy roads you need plenty of well damped rebound.  You have to keep the tire on the road. Cant waitto see it and hear alll about it in use!
[SIGPIC][/SIGPIC]-Scott
1991 E30 M42
« Reply #19 on: February 26, 2008, 07:20:52 PM »
I'm confident about my choice, springs and shocks are in the same configuration as most of rallyemen choose regarding the type of roads we have in our region, and my car will be first a street use car with some track days during the year...
my tires: Hankook ventus Z211 205/55r15, the only size allowed in France for 15 inches wheels on e30
and an example of one of the operation to light my car:
how hard was the sound deadening to remove, looks like you did a good job
CO318is
« Reply #20 on: March 03, 2008, 11:29:32 PM »
Quote from: 1991 E30 M42;43666
I have found that dry ice works the best for removing sound deadening, get a couple of big chunks place it on the deadening for a couple of minutes then hit with a hammer and it will chip up, then go back with a degreaser to remove the rest of the residue.
This project looks great sounds like a really fun car!
supermaaneuh
« Reply #21 on: March 04, 2008, 01:38:38 PM »
Quote from: CO318is;44082
Everything  has been said, thanks
supermaaneuh
« Reply #22 on: April 04, 2008, 05:30:08 AM »
epoxy coated parts
new gearbox from an e36 318i:
wheel with tire:
a mean to light your bumpers:
more fresh air:
Before:
After:
face lift:
White325is
« Reply #23 on: April 04, 2008, 05:56:53 AM »
oh wow, your car is very clean.
Nick_318is
  • -Receive: 11
« Reply #24 on: April 04, 2008, 06:46:01 AM »
This is a BIG TEASE, your car is going to be awesome and it looks great from what you have planned and have shown us.  I think those wheels will look great.
Cobra Jet
« Reply #25 on: April 04, 2008, 07:22:00 AM »
c'mon now, post up some MORE PICS!
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
ose30
« Reply #26 on: April 04, 2008, 09:07:00 AM »
Quote
in France and Europe, we never heard about any airbag in an e30, and the 318 is is originally equiped with Mtech1 steering wheel
Air bag was available on special order basis, otherwise MTech I was oem streering wheel.
Looks really nice project. You have done great job there :)
We have here in Europe one advantage over US models is the general lack of accesories on Euro models. For example i don't not have the following "normal US-spec things:
A/C
Sunroof
powersteering
power windows
power trunk lid
power central lock
etc.
I suppose Euro spec cars are quite a lot lighter than their US-spec brothers.
If You are planning to use Megasquirt i suggest you to take a look VEMS http://www.vems.hu
It's quite similar system compared to Megasquirt, it only have a little bit better processor. Lot's of hardware available for it. You can tune it with same Megatune program as megasquirt.
BTW. do you have BMW OEM towing hook in your car? i suppose it can be seen in one of the pictures you post here.
Quote
How do you like the MTech-1 steering wheel? Was the conversion pretty straightforward and did removing the airbag cause any difficulties?
I suppose BMW is the same compared to all other Motronic system cars. I have removed airbags from several US spec Porsche 944 Turbos. You just need to remove air bags and after that you need to cut one wire from Motronic box and connect that wire to another wire (don't remeber which wires have to check them out). If you just remove air bags car won't start. That is mainly because motronic gets an impression you have had an accident and air bags has been blown this causes automatically the shut down of the engine and also fuel pump will stop. But it's quite easy thing to by pass this and all electric work can be done in few minutes.
Quote
325i motor steering (not sure of the translation) lighter than 318is one but needs to be relieved
Have you checked out 318I flywheel (for our american friends, not US spec wheel)? I suppose it is already what you are looking for.
« Last Edit: April 04, 2008, 09:27:38 AM by ose30 »
Malaise
« Reply #27 on: June 06, 2009, 07:13:31 AM »
Cool project man. :cool:
More pics are always welcome. :D
(from wich part in france are you from)?
« Reply #28 on: June 06, 2009, 07:42:35 AM »
Quote from: ose30;46113
+1 on the VEMS.  Has a built-in WBO2 circuit, just wire up a Bosch UEGO and you're ready to go.
Nice bit of work going on there...looks like your car started clean and is getting cleaner by the day!  Those wheels are striking in gloss black!  Definitely post more pics after you get them mounted.
