Does anyone know whether a lighter flywheel will put more stress on other driveline components? (ie driveshaft, diff, etc)
Everyone says that acceleration increases with a lightened flywheel; if the engine is capable of turning these components more quickly, wouldn't this mean more stress is placed on them as a result?
I understand that power output of the engine doesn't change, but more force is passed on to the driveline now because there is 5kg less weight soaking up these forces?
That's a good point, but I would guess that if everything south of the tranny is in good shape, you shouldn't have any problems. Make sure your diff is working well and no leaks, check your guibo (not Febi Guibo :cool: ), and centre support bearing.
I'm going with the M20 flywheel conversion simply because of the relative low cost and sprung clutch should eliminate any of this "chatter". BTW, did the fluid change in the tranny fix the chatter problem?? Would love to see a report on this.
People keep scaring me when I tell them I'm converting to a single mass. I hear everything from "It won't idle right because of the harmonic balancer", "you're gonna stall it all the time", and "driving in traffic will be a real pisser"... This all makes me uneasy, but I still think that stock flywheel is SO heavy you could reduce the weight easily in 1/2 or more without any significant drivability issues.
Hearing about good results with a 9 lb flywheel gives me some comfort in knowing I shouldn't have any problems with a 16 lb flywheel.
