Author Topic: Upper strut mounts.  (Read 5121 times)
Upper strut mounts.
« on: April 27, 2006, 01:37:02 PM »
What are the signs that the upper strut mounts need to be replaced. I referring to the rubber mount with three studs that bolts to fender apron and is on top of the strut/spring assembly. Do they bang when hitting a pothole or a bump in the road?
Febi Guibo
  • m42 reporter
Upper strut mounts.
« Reply #1 on: April 27, 2006, 01:50:28 PM »
I'm not really sure... I replaced mine when I did my shocks/springs for the hell of it, but my old ones looked fine to me, very little difference.
It's basically a giant rubberized 'mount' with a bearing race and those three threaded pins.... I guess if there was a weak point it would be those pins?
I suppose if there was somehow some play between the mount and the nut on the shock piston, you'd hear it at some point?
are you hearing a banging or something?
Support M42club.com !!
She bang!
« Reply #2 on: April 27, 2006, 02:52:13 PM »
It may be a tie rod ends. I think they are about due. But there's also a banging when hitting a bump. It sounds similar to the bang from worn rear shock upper mounts or rear suspension bushings but it's in the front.
Upper strut mounts.
« Reply #3 on: April 27, 2006, 05:28:33 PM »
You'll hear a loud bang/clunk when you go over large bumps or potholes like you said.
M42Iberia
Upper strut mounts.
« Reply #4 on: April 30, 2006, 12:52:10 AM »
control arm ball joint maybe...
M42boy
Upper strut mounts.
« Reply #5 on: April 30, 2006, 10:23:18 PM »
Quote from: D. Clay
You can replace that whole unit with an adjustable camber plate that also has a much better spherical bearing design.
Bang!
« Reply #6 on: April 30, 2006, 11:33:55 PM »
The control arms are new w/less than 3K on them. I've checked everything for slop and play and it all seems Ok. I know they are a weak spot with Camry's. The srvice dept. at the Toyoto dealer told me they usually put in 6-8 sets on the first cold day after a warm spell. The shocks are stiffer with cold fluid. It gets better as you drive it. I also know some cars rarely have this problem. I didn't know about E30's. The rear shock mounts on an E30 are notorious from what I hear.
