Author Topic: Dome Light  (Read 7178 times)
jpod999
Dome Light
« Reply #15 on: November 23, 2007, 10:41:43 PM »
Nice mirror!
ultimatejohn
Dome Light
« Reply #16 on: November 24, 2007, 02:43:00 PM »
Instead of installing a light into the existing check panel, would it be possible to pull out this one and replace it with the other (spaceship) check panel? I've always thought those were bad ass and it would be cool to run an "all systems go" check before taking off down my windy little roads haha.
Dome Light
« Reply #17 on: November 24, 2007, 04:37:47 PM »
Thanks for the wiring info. Does the weather stripping just pull off, or is it glued on?
The check panel won't work with our cars because the wiring isn't there to run them. The sensors aren't even in the car, from what others have said. It would be way too much work just to be able to press that little button...
AL GReeNeRy
Dome Light
« Reply #18 on: November 26, 2007, 02:17:18 AM »
Quote from: gearheadE30;38270
i actually replaced my weatherstripping on the drivers side and there wasnt any glue so it should just come right off. as for the check panel, theyre annoying.  i had an 89 325i auto before and i could never get all of the lights to function properly.  a sensor was also broken or somethin.  its pretty much the same in all cars with that check panel
1991 318is : brilliantrot
