Author Topic: Which E30's come with M42?  (Read 20565 times)
dublinboy
« Reply #15 on: May 20, 2008, 05:22:20 PM »
just to add another late one here.....
here in ireland, THE M42 wer available from 1989. just like my 318is which is now off the road due to a cracked cylinder head :(
318is e30
IRELAND
949Racing
    • http://www.949Racing.com
« Reply #16 on: May 23, 2008, 07:14:49 PM »
Quote from: sheepdog;37597
In the U.S. any 318 (e30 or e36) between 1989 and 1995 used an M42.
Though technically they did not import them into the U.S. until 1991 according to the government, some may have slipped in as gray market.
Just look for a 1991, it will have what you want.
Still confused. 89-90's came with both the M40 and M42? I'm shopping for one and would like to know a quick way to identify the M42's without the owner needing to be an expert.
wanganstyle
« Reply #17 on: June 11, 2008, 12:40:05 AM »
hmm, so my 91 with LSD is a good find? a quick left turn + graby clutch let me burnout mid turn nicely and make funny little tires squeal for a while :P
1991318is
« Reply #18 on: June 11, 2008, 02:16:42 AM »
Quote from: 949Racing;49982
I'd say look for the coil on plug setup sitting on the passenger side fender. Also the valve cover has a center black section in the middle of it that's plastic and covers the spark plugs.
BMWManiac
« Reply #19 on: June 23, 2008, 09:45:37 PM »
Can I retrofit the check panel behind the rear view mirror?  Mine has some panel that just blinks SRS!  I bought a check panel off ebay and will see if it fits, if not, I'll just sell it to someone else.
2006 Interlagos Blue Z4M Coupe
Premium pack, navigation, heated seats
1997 Artic Silver M3
Built motor + SC62 + TRM tune
545rwhp/520rwtq
LomiTumnidona
it's not jokes
« Reply #20 on: April 10, 2009, 07:37:26 AM »
why I can not quote?
_________________
Illustrated guide what to look for when buying a used car
Maybach 57, 62
deekay
« Reply #21 on: April 10, 2009, 11:34:10 PM »
US-market cars never got the M40, and i doubt someone would go to the trouble of grey-marketing a base-model 318i when you could get the same thing with a twin-cam from the dealership stateside.
google "unixnerd bmw john burns"- guy runs a good enthusiast site, and IIRC he has a pictures section, you should be able to find help visually id'ing an M42 from there. i'd get you a direct link but i'm at work and the proxy blocks his site.
Pac_Man
    • http://www.PSUK.BTtradespace.com
« Reply #22 on: April 14, 2009, 05:39:02 AM »
Surely the M42 is easy to spot becuase od the DHC?
Alpine White E30 318is
RidingSimple
« Reply #23 on: April 24, 2009, 03:14:30 PM »
Quote from: G-Man;37442
The M42 came in the US market in the 91 model year (last year of E30 except for E30 conv). The M42 came in three versions but all E30 only came with a 5 speed manual gearbox.
-sedan
-coupe
-conv
The desirable model is the coupe with Recarro seats, OBC, limited slip, spoilers, basketweave alloys,etc..  Prices are rising on this car because it is considered an enthusiasts car (poor man's E30 M3).
The sedan has the same mechanicals (but I doubt many came with a limited slip) and a cheaper price. The sedan came without the OBC and check panel near the rear view mirror. It also came without the sport seats, spoilers, etc.. Steel wheels with hubcaps were standard on the 91 E30 318i sedan instead of alloy wheels.   Their are some great bargains out there on 318i sedan's.  I know, I bought one for $1.2K in Aug 06, one owner with only 118K on car.  Car had issues and they spent a fortune trying to figure it out so they gave up on the car.  Turned out to be a bad ECU. I had to buy a 91 318i sedan parts car (hit hard on pax side) for $450 to start swapping parts and figure out what was wrong.  It was my gain because I now have a lot of parts. I do like the 4 door model better than the two door.  Some E30 bottlecap alloys really dressed up the car, it looks so much better without the steel wheels and hubcaps.
-The E30 M42 conv ran for two years, 91 & 92 since the E36 conv wasn't ready so the factory sold the E30 conv, E36 coupe and sedan side by side. Conv tops can be expensive.
You'll find lots of 318i's FS on Craigslist, hope this helps.
If you live in the SF Bay area, also check out http://www.baye30.net a great resouce for No Cal E30 owners.
G-Man
Good info, but one thing is incorrect.  91 US 318is models do not come automatically with the check panel. Both of mine have had blanks there, just the Airbag light.  Both of mine have also been ordered with the LSD (also an option, didn't come without ordering it like many believe) and without the sunroof.  Lucky huh? ;)
xwill112x
« Reply #24 on: April 24, 2009, 03:33:21 PM »
and the 318iC vert ran into april of 93'  not just 92 :)
Ich liebe meinen E30
cassiematttann
« Reply #25 on: October 31, 2009, 09:24:46 AM »
hi i have a k reg 318is coupe, ow i believe it is an m42 enigne iam having problems with it hunting at the momment when it is cold but once it has warmed up it seems fine. the engine diagnostic threw up that the crank vent valve is dodgey but i have bought one which appentley goes on the intake maifold but i have taken my appart and i do not have one of those crank vent valve on mine so now iam kinda stuck any ideas please
