Author Topic: Spec's E30  (Read 12552 times)
jpod999
Spec's E30
« Reply #15 on: January 06, 2008, 09:03:27 PM »
Why is there a space above your kidney grilles?
Spec's E30
« Reply #16 on: January 07, 2008, 09:01:06 AM »
Before you get that all fiberglassed together, take the front bumper off and fix that panel between the grills and the bumper. It is screwed into the lover valence, btw. Plus, it will fix most of your front-end alignment problems. Otherwise, looks good.
Spec 2
    • http://www.pnwriders.com
Spec's E30
« Reply #17 on: January 07, 2008, 08:36:23 PM »
Quote from: jpod999;40613
Is that not supposed to be there? I'll have to go look and see if something is misaligned?
Quote from: gearheadE30;40638
The passenger fender is an aftermarklet fender, and I have a dtock one I'm prepping and going to fit on.  At that point I'll worry about bending back out that piece I believe you're talking about.  That should clear up all the lines in the front.
jpod999
Spec's E30
« Reply #18 on: January 07, 2008, 10:35:16 PM »
Yeah, that gap isn't supposed to be there.  Look at the difference between this car and yours:
Spec 2
Spec's E30
« Reply #19 on: April 14, 2008, 12:52:01 PM »
Ok updated pics! :)  Things are coming together finally.  I've repaired more of the damage up front. I still need to adjust the hood and replace one piece of the upper valence behind the bumper, then everything should align correctly.  It's getting close though.  Work in progress....  Still have lots to do to this thing.
Enough rambling, on to the current pics. Enjoy:
PartsCar
Spec's E30
« Reply #20 on: April 14, 2008, 02:25:40 PM »
i came.
Zilla
Spec's E30
« Reply #21 on: May 09, 2008, 12:56:30 AM »
i love it, any updates so far?
Kilawin
Spec's E30
« Reply #22 on: May 09, 2008, 10:34:39 AM »
Nice work...but diffently deserves better than Taurus skirts.
vatos_p
Spec's E30
« Reply #23 on: May 12, 2008, 02:27:29 AM »
with these rims the car looks great...
steer with the rear !!!
iwantspeed
Spec's E30
« Reply #24 on: December 16, 2009, 01:50:14 PM »
looks really good on the alpina's
1987 325e
5 speed
removed power steering
removed all trunk tar
removed all carpet lining
z3 1.9 short shifter
and maintenance up to date.
