Author Topic: clutch pedal pulsating  (Read 3406 times)
n2motorsports
« on: November 02, 2007, 09:56:11 AM »
is it normal to feel the clutch pulsating while shifting gears?  could this be a sign of a bad clutch slave cylinder or bad motor mounts?
car shifts into gears smoothly, without any slippage.
EN318isPDX
« Reply #1 on: November 02, 2007, 10:00:21 AM »
Quote from: n2motorsports;37048
I'd guess maybe one of your tranny mounts? not really sure though im thinkin it might be one of them not being bolted on
haledj
« Reply #2 on: November 02, 2007, 10:46:15 AM »
it could be your throwout bearing, if it is it will start squeeking/grinding soon
sheepdog
  • Site Admin
« Reply #3 on: November 02, 2007, 11:39:21 AM »
Could also be that the pressure plate fingers may be failing. Had this happen on a pickup.
I would check the engine and trans mounts and if they are good, start planning on a clutch job. Even if it is only the T/O bearing, do the entire clutch while you are there.
EN318isPDX
« Reply #4 on: November 02, 2007, 12:11:00 PM »
Quote from: sheepdog;37055
When i got my car the guy told me the clutch was bad. Turned out it was the hole tranny. I had about 25% left on the clutch disc so i replaced EVERYTHING anyway. New clutch really made me happy, i am glad i didnt put it off
n2motorsports
« Reply #5 on: November 02, 2007, 02:07:49 PM »
has anyone replaced their clutch themselves?  I haven't really been under the e30 much, so im not sure how difficult it is to reach some of the bellhousing bolts....it's an absolute pain on my nissan.
EN318isPDX
« Reply #6 on: November 02, 2007, 02:30:35 PM »
I have done it recently on my M42 and the hardest bolts to get out was the ones from behind the bell housing that holds the starter in. They have a nut on one side so i had to tag team it to get it out
« Reply #7 on: November 03, 2007, 05:32:29 PM »
As for checking the engine mounts, how far should the upper pan be fromt he steering rack? I can move the engine my pushing on the upper intake, and it makes a bit of a thunking noise.
DCColegrove
    • http://www.bandcforeigncar.com
« Reply #8 on: November 04, 2007, 02:47:09 AM »
If the pedal is pulsating it is probably either the T/O Brng or the Pressure plate...
 It would be nuts to pull the trans and only replace one or the other though so...
 We say you need a clutch
eric ^__^
« Reply #9 on: November 09, 2007, 02:55:37 PM »
Quote from: haledj;37053
yep, mine is squeaking now. I wonder how long I have! Replacing the clutch/bearings on wednesday. It's amazing how long you can go with a bad clutch.
I've read a few posts about installing a lightened M20 flywheel. Oddly enough there just happens to be a lightened/balanced M20 wheel at the shop as we speak.
I wish I had time to get the clutch balanced, but oh well.
