Dinan Chip?
Author Topic: Dinan Chip?  (Read 20661 times)
pwforprez
Dinan Chip?
« Reply #30 on: November 29, 2007, 01:39:30 AM »
that looks pretty good.. anyone have a sheet with the markD 93 octane or should it be around the same?
pwforprez
Dinan Chip?
« Reply #31 on: November 30, 2007, 01:10:22 AM »
a friend is letting me use his dinan chip for my car..  just got to drive around for a few minutes and it really is nice.  its forsale if anyone is looking for one..
seeing how this one runs really makes me want to get the chip i want
RIPDOTCOM
Dinan Chip?
« Reply #32 on: December 21, 2007, 08:49:47 AM »
Just thought I would add a not about ebay chips. I have had 2 X 325E's, 2 X 325I's, 4 X E36 325IS's and 4 E34 525I's, a 735I and a 635CSI. I have used, TMS chips, Dinan chips and the cheapo ebay chips (xg-motorsports). I can definitely say that the cheap ebay chips gave the eta's the same performance gains with no adverse effects as the dinan chips did. I actually had 2 eta's at the same time one chippe dwith dinan and the other with a cheapo and the performance was identical. I have only used 1 other ebay chip on an E36 325is and there was a very noticable gain. The tms chip I used was for my S50 conversion I did and it was the kit with the 3.5" maf so there is no contest comparing that one. All of my E34's had dinan chips but I woul dnot be afraid of running a ebay chip from the right seller (in this case xg motorsports) I just ordered one for my 318I sedan and will post some butt dyno results when it gets here.
RED IS 91
Dinan Chip?
« Reply #33 on: December 21, 2007, 11:27:59 AM »
Quote from: RIPDOTCOM;39846
I'm interested in the xg motorsports chip also .
Look forward to your butt results. It doesn't say what Octane the chip is made for.:confused:
RIPDOTCOM
Dinan Chip?
« Reply #34 on: December 21, 2007, 04:12:26 PM »
I sent him an email and he stated that it is for 91 octane like the rest of the, Also emailed me a set of instructions. Funny thing is that the instructions are written by ac schitzner. Maybe its just a copy of the eprom. No complaints from me on any of the other chips, im sure this one will be just as good as the others.
Heres a copy of the email.
Installation Instructions
Removing the ECU from the car
E30 3-Series
1.)   The Ecu is located inside the car. Open the glove box. Remove the pins securing the glove box door to the mounting straps. You can let the glove box door rest on the floor
2.)   325E: Remove the Phillips screws on the front of the black plastic cover at the top of the glove box. Remove the black plastic screws at the rear of the black plastic cover. Pull this panel down and set it aside.
3.)   Remove the 10mm bolts or the Phillips screws securing the engine control unit
      (ECU) to the dashboard.
4.)   Unclip the metal fastener locking the wiring harness into the ECU and remove the
harness. Take the Ecu to your workbench.
AT YOUR TABLE
1.)   The Bosch part number on your ECU must be 0-261-200-175. If this number is not printed on the label – DO NOT INSTALL THE PERFORMANCE CHIP, your car will not be happy!
2.)   Place the ECU on your table with its part number label facing down. Use a small pocket screwdriver to pry up the six locking tabs securing the ECU’s cover; pry each tab up only enough to insert the medium screwdriver. Use the medium-sized screwdriver to finish prying the tabs upward until they’re vertical. Be careful; the tabs will weaken with repeated prying. Remove the ECU cover and set it aside.
3.)   Locate the socketed chip on the printed circuit board. Clue; the chip is secured with a white plastic clip in the shape of the letter “H”.
4.)   Remove the retaining clip by inserting the pocket screwdriver into one of the small slots in the clip’s side and prying toward the other slot. The retaining clip will pop up on the side in which the screwdriver is inserted. Use your fingertip to hold that side up while you repeat the process for the other side. Set the clip aside – it will not be reused.
5.)   This step is VERY important! By removing the original chip, examine how it is oriented in its socket. Particularly note where the “divot” is positioned. On some cars the divots maybe on opposite ends from each other. On others they may line up. IT IS CRUCIAL TO YOU THAT REMEMBER WHICH END THE CHIP’S DIVOT IS INSTALLED ON! Remove the chip from its socket with the pocket screwdriver. Insert the blade between the chip and the socket and pry gently upward. Alternately pry each end of the chip until it is COMPLETELY loose. WARNING: pry the chip from the socket – not the socket from the board! As you remove the chip from it’s socket, grasp it by the chip itself and not by the pins. THE PINS ARE FRAGILE! Keep the stock chip – you may want to reinstall it later.
6.)   NOTE: the pins of all computer chips are very fragile! Every chip that leaves AC Schnitzer is inspected for quality. If the pins on the module, encryptor board ever become bent or tweaked DO NOT attempt to bend them back into place. AC Schnitzer will not be responsible for broken or damaged chips. Call us for instructions on getting a new chip sent to you.
7.)   Remember the Performance chip must be oriented in the socket in the same fashion as the original chip was (this is why step 5 is critical). The chip has a U groove on it. This is the divot end. Rest one row of pins from the Performance Chip on the socket. Ensure that each and every pin lines with a corresponding socket hole. If each pin lines up then gently push down on each row to LIGHTLY set the chip in the socket. Avoid bending and flexing the printed circuit board while inserting the chip. Apply firm but gentle pressure on the chip during installation. Push down on the chip until it “clicks” into the socket. NEVER bend any of the pins to ease installation. Visually verify that all of the Performance Chip’s pins are in their corresponding socket holes and that all of the socket holes have pins.
8.)   The white plastic retaining clip will not fit over your new Performance Chip.  This is not necessary for the vehicle to run.  Reinstall the ECU’s cover in the reverse order of step 2.  Use the pliers to bend the locking tabs back into place.
9.)   Reinstall the ECU into the car and plug the wiring harness back in.  Start the car and ENJOY!
RED IS 91
Dinan Chip?
« Reply #35 on: December 21, 2007, 04:28:52 PM »
38 bucks looks like a very good deal if it does what they say .............
For under 50 bucks with shipping I might get one and put  it in in the spring.
Xmas for me :D
1991318is
Dinan Chip?
« Reply #36 on: January 08, 2008, 04:53:01 AM »
Quote from: Shift_Now;38112
Has anyone actually had any problems with the "eBay" chips?  I bought one last year and I have put over 30,000 kms on with it and I have had no problems and I regularly take it to 6900 RPM.  It seems to be fine and I run 91 octane Shell or Esso gas.  From my understanding they were just burnt Dinan or similar tuner copies.
Had an ebay chip in mine, was great for 6 months then just as people said to be leery of, it fried the ecu...
Pay the extra and get a good chip IMO. I coulda got a markd chip for what I ended up having into getting the ebay chip and then the new ecu.
JHZR2
Dinan Chip?
« Reply #37 on: January 10, 2008, 07:02:05 AM »
my question is what about emissons performance. Dinan, IIRC is certified legal in 50 states for emissions.
Others may or may not have effects o emissions.
My dinan chip passed with flying colors on the dyno test...
JMH
Shift_Now
Dinan Chip?
« Reply #38 on: January 10, 2008, 07:25:01 AM »
Quote from: 1991318is;40698
It seems to me that if the chip was to blame, it would have fried the ECU right away?  Maybe I'm wrong.  You sure it wasn't a bad coil, I've heard they can cause damage to the ECU
Nick_318is
  • -Receive: 11
Dinan Chip?
« Reply #39 on: January 10, 2008, 12:49:33 PM »
I have a dinan Chip and I really like it.  I always hear great things about the mark d chip and am really thinking about picking a 93 chip up from him.
Frankie
Dinan Chip?
« Reply #40 on: January 14, 2008, 02:20:14 PM »
Well, I just bought that XG Motorsport chip. I gonna dyno it within few months time (april, may maybe).
pwforprez
Dinan Chip?
« Reply #41 on: January 28, 2008, 02:14:14 AM »
i ordered the markd 93 oct chip i cant wait for it to get in.
MarkD
    • http://www.dsylva-tech.ca
Dinan Chip?
« Reply #42 on: February 23, 2008, 01:28:35 PM »
Quote from: pwforprez;41816
Thanks for ordering one of my chips instead of a clone from eBay.   All those guys do is copy someone else's work and sell it to you.    I've got more TENS of thousands in equipment (and countless hours of work)  than you can imagine invested to develop my chips.  (actually I should change the word "investment" to "spent"  as it's not really making a positive profit.   :(
sumyungguy
  • b.wood
    • http://www.shutterflick.com
Dinan Chip?
« Reply #43 on: February 23, 2008, 02:23:47 PM »
Quote from: DaveM-sport;38446
taken from E30zone.net
This is a great definite answer to what a good chip does to the M42 instead of all the claims people state.
The low down torque gain is crazy
The quoted dyno results don't show air/fuel. Their results are inconclusive without that because, sure you can make lots of power but how close or over "the line" are they to making the tune unsafe. That tune could be dangerously lean and timing far advanced, that would make power but be extremely unsafe for the motor, IE detonation..
I am only commenting on this because their claimed power gain seems unrealistic to be safe.
brad™
velomech
    • http://www.addictivecycles.com
Dinan Chip?
« Reply #44 on: February 23, 2008, 03:36:17 PM »
Quote from: MarkD;43405
Mark,
Had I seen your chip first, I would have gotten it. I bought one from ebay, and you saw the results. Although, all in all it was only $50, when you did your GROUP BUY, it would only have been $150 bucks more.  WHich is a steel for afew more HP.
Maybe I can unload mine locally and get one from you. Being a local bike shop owner, I know how important it is to support the locals and your sponsors. So, a sincere apology, and look forward to seling me one shortly...
CHeers and beers
Hodge
In the words of the Immortal Freddie Mercury..."Get on your bikes and RIDE!"
