M42 swiss
Author Topic: M42 swiss  (Read 14530 times)
ispierrot
M42 swiss
« Reply #30 on: October 04, 2007, 03:19:29 PM »
Tanks.
Just the M44 distribution of fuel on the injectors M3.
Royalratch
M42 swiss
« Reply #31 on: October 13, 2007, 03:29:03 PM »
How did you solve the engine temperature sensor problem?
I have an M44 in my E30 and the M44 has only 1 sensor but the E30 requires 2.
Maybe you're not using your engine in an E30 but any ideas?
ispierrot
M42 swiss
« Reply #32 on: October 13, 2007, 03:39:17 PM »
I have an M42 engine and a car E30
It fuel distribution to the M44
« Last Edit: October 13, 2007, 03:44:39 PM by ispierrot »
Royalratch
M42 swiss
« Reply #33 on: October 19, 2007, 08:22:19 AM »
Hello ispierrot.
Can you explain that a little more?
ispierrot
M42 swiss
« Reply #34 on: October 19, 2007, 04:06:41 PM »
Hello.
The engine is still in my workshop, I seek an electronic management simple to understand and use.
EN318isPDX
M42 swiss
« Reply #35 on: October 19, 2007, 04:23:53 PM »
Quote from: ispierrot;36109
Hello.
Megasquirt is your friend!
http://www.megasquirt.info/
Royalratch
M42 swiss
« Reply #36 on: November 14, 2007, 07:01:32 AM »
So how is this project going?
ispierrot
M42 swiss
« Reply #37 on: November 17, 2007, 04:07:30 PM »
At the moment I try to find an air box and concluded a few things, before mounting in the car.
Recently I went on a tour with a small engine, 1796cc. 151 ps.
See you soon.
http://fr.youtube.com/watch?v=5rdOmFsQRNE
http://fr.youtube.com/watch?v=rqEKXn3nEzc
http://fr.youtube.com/watch?v=_hyM7SMDQGc
http://fr.youtube.com/watch?v=hRowFBcgdi0
ispierrot
M42 swiss
« Reply #38 on: November 17, 2007, 04:16:53 PM »
The engine of 151 PS is presented here.
Early preparation engine M 42.
Here I present to you a little preparation I made a little over a year, I am an amateur like most of you, so there is no scientific computing, but rather a logical staff "In addition to reading, which deals with the preparation of the engines a little patience and passion.
Budget around 2500 to 3000 euros
The yoke
I dig little 1 mm. On the radius and then sanding depending on the desired finish and guides nine, the report volumetric is 10.5.
Adjustment of inlet pipes
With a red lip on the paper then pipe on the cylinder head coach on greenhouse is removed and the path is made that there is no longer widening.
Piping
Even work on the cylinder head
The valve lifters, springs and distribution
Valves origins 7 mm. New, springs DBILAS doubles and push origins, distribution is new,
Camshafts
262 degrees at DBILAS, pulleys are adjustable home
The rods
New original 140 mm. Then lean polished
  Balanced weighs on the foot of the rod all the same weight and then head all the same weight and complete all the same weight.
Pistons
Originally 84 mm new segments
Engine block
The cylinder is déglacé to stone.
The crankshaft
Poli and balanced, polishing my taking three months during my lunch break, not all good either breaks
The shuttle engine
325 i balanced, which has replaced the 318 has the advantage right because it is lighter and that the clutch of origin 325i is stronger
Injection
Originally + injecteur 233cc.
Electronics
Originally, chip comes from Germany I do not recall most of what Blocker?
This engine running for one year without any problems with a maximum 7500t/min, I have not spent on the bench but it should come it is well supported by a box M3 and a sleplimited 4 / 10
My English just google translation, sorry.
See you soon.
« Last Edit: November 18, 2007, 11:11:12 AM by ispierrot »
Vladi
    • http://www.bmwzone.ro/forum
M42 swiss
« Reply #39 on: November 17, 2007, 05:03:57 PM »
How did you polish the intake? :)
ispierrot
M42 swiss
« Reply #40 on: November 17, 2007, 05:27:01 PM »
With DREMEL and mixture to polish for metal or aluminum
and
suvi123
M42 swiss
« Reply #41 on: November 19, 2007, 12:49:29 PM »
Why didn't you polish rods everywhere? only "sides" and from the "top"?
ispierrot
M42 swiss
« Reply #42 on: November 19, 2007, 04:25:36 PM »
The Polish I rods
1) for the strength, so the polish or there is likely to break.
2) to ease, so the piston side is more important.
Royalratch
M42 swiss
« Reply #43 on: February 15, 2008, 01:20:06 PM »
Any more news?
M42 swiss
« Reply #44 on: February 15, 2008, 01:48:01 PM »
je suis jaloux! vraiment beau projet et j aime particulierement tes videos sur le circuit de Bresse! je vois que tu clanches ton 1.8 a fond
donnes nous des nouvelles!
