Author Topic: 318is M44, what T3 turbocharger between these?  (Read 10432 times)
WeirdYo2
« Reply #15 on: August 25, 2007, 11:41:03 AM »
Its hard to tell what will be the best, everything changes with every turbo setup between what parts you use, you kindof have to just pick one and hope it works out good.  I've seen several people research what turbo will be best for their car and finally get the one they want, the turbo blows so they go and pull a turbo off a deisel truck and ends up being much better turbo for the car.  I am happy with my t3, I built my car for a streetable track car and it works out good.
nuvolarossa
« Reply #16 on: September 03, 2007, 02:29:53 AM »
Quote from: Tor Arne Kaasen;32150
go with the T3 60 TRIM, .60/.48 from SVOs, thunderbirds...
If you make a ok manifold. than you shud get full boost at 3000rpm. and star charging at 1500rpm i gues
but go for 8-10 psi of boost, more fun. more HP.
I was wrong: SVOs don't have .48 A/R turbine housing, but it's 0.63.
Merkur XR4TI has .48turbine and .60 compressor like I want.
I bought a T3 60 trim, .48turbine and .60compressor fully rebuilt:D
Now I'm searching to buy fast a great manifold!
« Last Edit: September 03, 2007, 02:33:52 AM by nuvolarossa »
Alibi
« Reply #17 on: September 03, 2007, 05:57:02 AM »
Cool!
  I think the T3 60 trim is almost the best choice. I am gonna use something like that too.
  About the manifold ... do you like this one:
nuvolarossa
« Reply #18 on: September 03, 2007, 08:02:36 AM »
Quote from: Alibi;32964
Cool!
Yes, T3 60 trim is best choice for performance/price ratio:D
That manifold sucks if you buy it from racetech.
That isn't their real picture.
The original of that manifold is produced from a Ebay user called "argopeti". Try to search it in ebay and ask him...
I emailed him many times, the racetech is built in china with a bad steel and really-thin = 1,8mm... the original of argopeti is 3mm!
But the original cost near 550 euro...;)
I'll buy neukin if they will answer me about shipping:rolleyes: or 666fab if he can do one for under 700$
(Alibi, if you want a eaton M62 supercharger I'll sell you mine from a 230k:D)
go turbo... I wrote you that S/C was too complicated! That is because I'm going turbo, even if supercharger "kit" was fitted and running:)
I wasn't secure to pull the car at very high speed with a belt that can came off because is not perfect aligned:o
and I know...
Alibi
« Reply #19 on: September 03, 2007, 11:08:37 AM »
Oh ... thanks for the tipps about the manifold. The Neukin looks really nice and it cost not so much. But how will stay the turbo (Down or Up) .. I mean Infront alittlebit over the Engine, or under the engine?
About the SC ... as I said... If I had the time to pull the engine off the car and spare some time on measuring and so on ... I would went for SC, but I didn't have that time, so I will spare some money and this Christmas I will go for turbo. We will stay in touch ... as I see, your goals are the same as mine :)
« Last Edit: September 03, 2007, 11:58:27 AM by Alibi »
Tor Arne Kaasen
« Reply #20 on: September 03, 2007, 12:12:23 PM »
yes the T3 60trim A/R 0,48 0,60 is a good choice.:p
i have the china manifold and it`s 1,8 mm thick. bad fitment. has to botum mont the turbo to use the manifold.:(
BMW E82 120d Coupe and BMW Z3 1,9 m44
Alibi
« Reply #21 on: September 03, 2007, 12:20:28 PM »
Is this buttom mounted?
And this?Buttom or Up?
nuvolarossa
« Reply #22 on: September 03, 2007, 02:15:17 PM »
Quote from: Alibi;32986
This up is the Neukin manifold. That on pic is topmount for a e36, with external wastegate....
This is top mount for a E30:D
nuvolarossa
« Reply #23 on: September 03, 2007, 02:18:19 PM »
Quote from: Alibi;32976
It's a e36. the frame around the engine leave minor space that a e30, so it will be bottom mounted;)
Great!
nuvolarossa
« Reply #24 on: September 06, 2007, 03:29:22 AM »
Yesterday the turbocharger have been shipped from USA to Italy :Dnow I need to buy a bit of other things :D
nuvolarossa
« Reply #25 on: September 08, 2007, 07:15:23 AM »
Placed order at turbogoods for Neukin's Turbo Manifold:)
Damn, they need 3-4 weeks to build it, because they have a huge number of orders now... I'll wait;)
I think that I'll buy this downpipe too, 3" inch:D:
searching for oil lines and water cooling lines too!
-where  are picked watercooling lines from in our cars? (pics..)
nuvolarossa
« Reply #26 on: September 13, 2007, 08:28:26 AM »
ops :D
sorry for low quality pics...
my T3, 60 trim, .48 turbine and .60 compressor....
directly from USA:
