Author Topic: Yet another Timing Chain Tensioner Post!  (Read 7487 times)
Vladi
    • http://www.bmwzone.ro/forum
« Reply #15 on: August 09, 2007, 05:55:05 PM »
So in USA the M40 flywheel doesn't look like this?
http://www.m42club.com/forums/attachment.php?attachmentid=345&d=1155158191
Wise Old Dog
« Reply #16 on: August 09, 2007, 06:27:21 PM »
It looks like the same FW to me, IIRC. The dual mass is split in half with a visible dividing line between the 2 halves. That looks like an M40 FW. Is that what you have? When you remove the PP, you will see the recessed friction surface on the FW. Here is what the PP and clutch disc looks like. Go to e-bay and look up this item. 160144298828
« Last Edit: August 09, 2007, 06:34:34 PM by Wise Old Dog »
Vladi
« Reply #17 on: August 09, 2007, 08:25:58 PM »
Quote from: Wise Old Dog;31316
I've got M20 one already. :)
e30s4evr
« Reply #18 on: August 09, 2007, 11:21:19 PM »
Well guys, I decided to take the lower pan off today! Fortunately all the upper oil pan bolts were intact and on tight! As I was celebrating my good fortune, I noticed 6 metal fragments in the oil pan. They appear to be the remnants of 3 cylinders all broke in half longitudinally. Each cylinder is about 1/4 to 3/8 inch long and about 3/16 inch inside diameter... just eyeballing these numbers. This happened 2 days after the m44 tensioner swap. Also just before oil pan removal I was noticing that the engine didn't seem quiet anymore! So do I need a new timing chain or are these valve guides?
  I'm debating what to do.
a) Timing chain and associated components replacement
b) Used engine.
c) Rebuilt engine Bavarian Engine Exchange.
d) Another 318is and swap upgrades
e) Set fire to both my cars and take public transportation from now on!
